This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #2611
    Originally posted by Mfever
    Wheel specs: 17X8 ET 22
    Compomotive TH
    Would I be able to fit these on a car with H&R race and billy sports without rolling fenders?
    Yup, with 215/40/17 tires. It'll be very close.
    • Mystikal
      • 9602
      #2612
      Originally posted by ejnight
      could you make a -10 off set work in the rear and what tire? Yes I have a fender roller.
      With a 6" wide rim, sure. Otherwise, not really.
      • Mystikal
        • 9602
        #2613
        Originally posted by stinkydriverx
        yoooo jay.
        just wanted to thank you for your help.
        The fronts (235/40/17) made it so i had to raise the front of the car up alot, probably an inch and a half. But i dont care about being low. I think it looks great!
        I told you i would show some pics when it was done!
        so heres the link tothe showroom thread
        http://r3vlimited.com/board/showthre...56#post1672656
        Sweet. What spacers if any did you end up using?
        • ejnight
          • Apr 2007
          • 3488
          #2614
          89 325is HR race-billys sports 16 7's +22 for the front 16 8's +10 for the rears what size tires? any rubbing or spacers needed. I want an aggressive look.
          Thanks for your time.
          http://raceskids.com/
          • Mystikal
            • 9602
            #2615
            Getting the sidewall heights to match will be tough. I'd honestly go with 205/45/16 all around.
            • ejnight
              • Apr 2007
              • 3488
              #2616
              I was hoping for a little more in the rear. what can I do?
              • Mystikal
                • 9602
                #2617
                Roll the fenders FLAT for a 215/45/16.
                • ejnight
                  • Apr 2007
                  • 3488
                  #2618
                  will do.
                  • TARGET
                    • Sep 2009
                    • 5
                    #2619
                    Hey guys, i'm looking at a set of 16x9.5" vette wheels, i can't find info on them other than:
                    16"x9.5" 38mm (6.7" backspacing)
                    I know the bolt pattern is wrong but I'm planning on running adapters, would these fit in the fronts or am i going to poke like it's prom night and I've been eating viagra like pez?
                    • Hammered
                      • Jul 2009
                      • 2
                      #2620
                      im not 100% but et is 49.5
                      • TARGET
                        • Sep 2009
                        • 5
                        #2621
                        does that mean they will fit?
                        • onaquest
                          • Nov 2005
                          • 805
                          #2622
                          That's a very aggressive offset. 205/45/16 all around would be my bet.
                          i went with 205/45. Great fitment thanks to evo3 and mystikal for their advice
                          http://bbswheels.blogspot.com
                          • erik325i
                            • Jan 2005
                            • 3567
                            #2623
                            Quick question:
                            Which wheel will stick out farther, a 17x10 with et20 or a 16x8 et11? How much farther will it stick out?
                            Thanks
                            Erik
                            • Kilawin
                              • Dec 2005
                              • 994
                              #2624
                              Originally posted by erik325i
                              Quick question:
                              Thanks
                              Erik
                              The 17x10. About 5/8" more.
                              • Mystikal
                                • 9602
                                #2625
                                You'd have to run at least 33mm of spacing just to clear the front struts. And yes, they'll be poking out A LOT without like 4 degrees of negative camber.
