This is a sticky topic.
Originally posted by Matt-BIm looking at getting a 75mm stud kit for stock 4 lug cause im tired of the coroded shit i use now.
am i good with a 8-10mm spacer on those studs?
Ill be running e38 style 5s, but mosty weaves
75mm is a massive stud, I wouldn't recommend it because you probably won't be able to get the caps on the wheels after.
Even a 60mm stud is enough for up to 15mm spacers.Comment
OK, I've read through most of the thread that pertains to 15x6.5 wheels...
Referencing a reply to a question about 15x7 ET38 wheels it was said to go with 205/55 tires with a 20mm Spacer for a flush fit.
Since my wheels are ET33 by my simple math I should go with 15mm spacers for a flush fit. However for maximum 'drivability' should I go with a 10mm or 12.5mm Hubcentric as shown in the ecstuning link above? I'm not as concerned with the 'flushness' of it all, I would rather have full range of suspension play without having to worry about fender or wheel-well rub since I'm not planning on rolling my fenders...
-RH
If you want to push them out a bit, 15mm is perfect. You won't even be close to rubbing, don't worry.Comment
www.gutenparts.com
This is a STRETCH... but would a 205/50 fit on a 9" rim?I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_TwinComment
Really? Would it look too goofy? I want to run an 8" rim in the front and a 9" in the rear. I have 205 tires for all around.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Delta Auto Care
Herndon, VA
703.435.1375
ok need some help. just got the car lowered. and i have keskin k1s. i know about having to run a 3 mm spacers for the car front to clear the strut. i don't like how high the car is and i want to run 205/50/16 instead of 205/45. would that be a problem. i was hoping to run a thicker tire to shorten up my gap some. let me know, thanks. keskins are 16x9 +15 offset
edit: or can you guys suggest a thicker tire that would work. im lowered on vogtlands so about 1.7 inches all around.Last edited by johnwoo; 07-11-2009, 12:25 PM.Comment
195/50 on a 9in. rim? Would that work? I thought I had 205/50s but I didn'tI got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Delta Auto Care
Herndon, VA
703.435.1375
hey what a thread!! well currently i'm running basketweaves 14" and have been wanting to get something else. Spinning out in the rain on an onramp into the median to I-95 has accelerated my move. I'm on a budget and was thinking of buying a set of 16" sportmax wheels maybe even 17" even though I can't find any 17's with the right offset. will I need to change to different lug bolts if i get the sportmax w/ offset 15?Comment
