Very much still addicted to wheels like these (and they are pretty light).  Is there any way to get these on my e30 318is?
	This is a sticky topic.
 Those offsets are good. Use 195/50 or 205/45 tires, in my opinion.Comment
 I've seen them mounted with 225/50 Hoosiers without spacers, although clearance is extremely limited on the inside. Street 225s are no problem.15x7 et27 Kosei K1's
 Can I fit 225/50 Hoosiers? What about 225/50 street tires? I don't mind rolling the fenders, just trying to avoid spacers. I need to figure out if I am using these wheels for street or track tires. If I can fit 225's, they will be my track wheels. If I can only do a 205, they will be my street/wet track wheels.
 EDIT: While I'm at it, 16x8 et20 Rota Slipstream
 Currently running 205/50/16 Hankook z214 R-comps. Can I run a 225/45 r-comp? Street tire?
 For the Rotas, 225/45s are no problem with just a fender roll.Comment
 You'd need to find out their offset (or backspacing, then I can calculate the offset). The offset would need to be high enough to run 15+mm of adapter behind them. Honestly, with anything that concave, it's going to be tough.Very much still addicted to wheels like these (and they are pretty light). Is there any way to get these on my e30 318is?
 http://sfbay.craigslist.org/sby/pts/1486211546.htmlComment
 Oh no I took ur advice!
 But ya know two heads are better then one!
 So I'm guesing the 225/50 would hit the strut up front?
 The thing is 225/45 are hard to find and the 225/50 are in stock everywhere I have called.
 Lol guess I'll have to bite the bullet.
 Any suggestions on a quiet smoth tire1986 RED ROSE (325es)Comment
 225/50 wouldn't hit the strut, it is just a larger diameter. yes, 225/45 is a hard size to find. 205/50 is a bit more common. if you want a quiet smooth tire, then get 205/50's instead of 225/45s. as for tire recommendations i'll let someone else chime in.Oh no I took ur advice!
 Any suggestions on a quiet smoth tireComment
 My main consern was firment with et25 if a 225/50/16 would rub anywhere.
 And if u recomend spacer front or rear?
 Cus I do have a good deal on some hankook optimo h rated 225/50/16
 don't mean too beat a dead horse but I will have to live with these tires for a while!1986 RED ROSE (325es)Comment
 fine, get the oversized tires. i'm done trying to explain to you why that is a bad idea.Comment
