This is a sticky topic.
  • Stephen
    Шлем ишака
    • 10774
    #2896
    15x8, 225/45
    ET20?
    :yawn:
    • v8fc3s
      • Apr 2009
      • 105
      #2897
      I have been looking for rims for a while...
      i have found this and i personally dont think they look too bad (especially for the $). not sure of the offset, i am going to check them out on saturday to see what it is.
      1. what offset would i need for it to fit?
      2. will the tires fit right for that size rim?
      THANKS FOR YOUR HELP!
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #2898
        Originally posted by Omaliyo
        Adapters
        I'd go with 20mm front and 25-30mm rear adapters then. 195/50 tires, or similar.
        • Mystikal
          • 9602
          #2899
          Originally posted by TheRooster
          offset 15.. also whats a good tire size?
          You can run the 16x9 all around with 3mm spacers on the front. They won't need longer bolts. You can also add 8-10mm spacers on the back to even out the fitment, but those will require longer bolts.
          I recommend 205/45/16, or 215/40/16. You may need a slight fender roll in the rear.
          • Mystikal
            • 9602
            #2900
            Originally posted by Eric
            Thanks for the lead on the DWS's i would have completely skipped over them.
            tire rack has them in 225/50 for the rear, but for the front i can run 205/45, 50, or 55. would the 205/45 look funny on a 8.5 wide wheel? the car will be very low on ground controls, so i'm not worried about wheel gap, i'm more worried about a tire too big, or too mismatched to the rear tire.
            I'm going to ask my local tire guy about these conti's so hopefully i don't have to wait 6-12 weeks for tire rack.
            Yeah those DWS' are fascinating tires. They are faster around a wet track than a dry one!
            If you're going with the 25" tire for the rear, you're going to want to keep it close at the front. 205/55 would be that. That's still a tall tire though, so you may want to back it down to a 205/50. It'll be your call on that.
            • Mystikal
              • 9602
              #2901
              You'd want the offset between 20-25 for a stock-like fitment. 95% chance those wheels are somewhere around 40 though, so you will need to factor in the price of spacers and bolts...and that pretty much doubles the purchase price of the wheels.
              As for tires, 205/55 is the proper stock size.
              • bmwsone01
                • 1212
                #2902
                Will 215/45/17s, all the way around, fit with BBS RF 17x8 et19.
                or should I go with 215/40/17, all the way around?
                I have h&r springs, and bilstein shocks and the spring pads were shaved.
                Thanks in advance.
                1991 318IS
                • sharky
                  • Jan 2005
                  • 2672
                  #2903
                  OK so I want to get a bit better stance with my car
                  16x7 Alpina's et 28
                  215/45/16 all around Falken Azenis
                  Running GC's w/ camber plates, 87 is w/ euro bumpers
                  What size spacers front and rear should I be looking at to get the wheels a bit more flush, not looking for stanceworks stretch and poke shit just a bit more filled and aggressive, hook me up!!
                  • thehapakid
                    • Aug 2009
                    • 26
                    #2904
                    GC Spring Rates for Staggered Setup
                    So I've been stalking/researching this thread for quite a while now and can't seem to find everything I totally need for my '91 318is.
                    I've picked up some ESM wheels in the 16x7.5 ET20 (205/45/16) and 16x9 ET10 (215/40/16) fitment and need some help with the spring rates on Ground Control coilovers without modifying the perch with Bilstein Sports. This is my daily driver and I was looking at spring rates of 350F/475R, but i'm not sure if that's right? I'd rather be a little soft on the ride than be overly hard.
                    What spring rates do you recommend to keep the wheels out of my fenders? Will I need camber plates too or will I have enough adjustment range with the OEM setup?
                    Thanks in advance, this is great work you do here.
                    • bmw320e21
                      • Jan 2005
                      • 67
                      #2905
                      Will 16x7.5 et 19 and 225/45s work without rolling?
                      Adam
                      • Wishno87
                        • 6025
                        #2906
                        Could i get a 16X8 at et -2 in the back with a 205/45 on an early model with fenders rolled flat? I have them at et 3 and still have some space and want to go out further.
                        • Mystikal
                          • 9602
                          #2907
                          Thanks in advance.
                          Go with 215/40. 215/45 is a very tall tire for an e30.
                          You'll also likely have a slight rub on the rear if you didn't roll your fenders yet.
                          • Mystikal
                            • 9602
                            #2908
                            16x7 Alpina's et 28
                            10mm front 15mm rear spacers would be nice.
                            • Mystikal
                              • 9602
                              #2909
                              Springs rates have little to do with ride quality actually. It's the dampers and tires that do the majority of the work. And with the Bilsteins, things will be pretty rough no matter what spring rate you go with.
                              Because of the aggressive rear offset, I'd go with 400/550 or similar. That's probably at the upper limit for what the dampers can handle, but I'd still shoot for that level of tension.
                              You won't need plates or anything else.
                              • Mystikal
                                • 9602
                                #2910
                                Yes on an early model, extremely close on a late model. Would come down to what springs it's running.
