This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #2911
    Originally posted by Wishno87
    Could i get a 16X8 at et -2 in the back with a 205/45 on an early model with fenders rolled flat? I have them at et 3 and still have some space and want to go out further.
    You're pushing it, but if you have 5mm of visible room there go for it. Worst case you swap the spacers out, right?
    • thehapakid
      • Aug 2009
      • 26
      #2912
      Originally posted by Mystikal
      Springs rates have little to do with ride quality actually. It's the dampers and tires that do the majority of the work. And with the Bilsteins, things will be pretty rough no matter what spring rate you go with.
      Because of the aggressive rear offset, I'd go with 400/550 or similar. That's probably at the upper limit for what the dampers can handle, but I'd still shoot for that level of tension.
      You won't need plates or anything else.
      Thanks!! You are the man, I'll be sure to post pics later.
      • Boosted E30
        • Dec 2009
        • 288
        #2913
        5-lug e30 with e36 m3 front and e30 m3 rear possible to fit 17x8.5 et13 all around? If so what tire size? possible 225/35/17
        • E30SPDFRK
          • 5688
          #2914
          16x10 in the back, whats the highest offset I can run before I hit the trailing arm/spring perch?
          Byron
          Leichtbau
          • bmwsone01
            • 1211
            #2915
            Go with 215/40. 215/45 is a very tall tire for an e30.
            You'll also likely have a slight rub on the rear if you didn't roll your fenders yet.
            Thanks! i just got a set of 215/40/17 and will post pics when mounted.
            1991 318IS
            • constructor
              • Aug 2007
              • 977
              #2916
              Jay,
              I have two options that I want to try and would like to know what issues I might run into.
              Car is an E30 convertible lowered on GC coilovers, low rear arches, fenders will be rolled.
              Option 1:
              16x8 ET12 225/45/16
              Option 2:
              16x7 ET-2 205/50/16
              Thanks in advance!
              • omar85
                • 331
                #2917
                ok wheel guys. I am trying to pick up a set of 15x9 -6 with a rim depth of 107mm. they are the same size all around. will i need a spacer anywhere? And, if someone has some pictures of something similar in size on an e30, even if it is 16x9, that would be appreciated.
                right now i have 15x8 et0 (sportmax) and they are slightly sunk so i think this new fitment will get rid of any sunkness.
                • z31maniac
                  • 17566
                  #2918
                  15x9 +7 will only be 5mm farther out then 15x8 ET0
                  www.gutenparts.com
                  • omar85
                    • 331
                    #2919
                    good point i will edit that out of the options. i need more then 5mm outwards.
                    i also got rid of the staggered option.
                    • NC325iC
                      • Mar 2004
                      • 6565
                      #2920
                      this thread is a mess, and its pretty hard to search through, someone should put together a table.
                      anyhow i am looking for some wheels/tires for my 86 (full fender wells in rear) right now im considereing the LTW5s which are 15x7 et25. this will be used mostly on the street but possibly some dual duty (until i can get a second set of wheels). Id like to get as much tire on the ground, obviously, since im going to swap the 3.0l stroker into this car. recommendations please.
                      Thanks
                      • johnwoo
                        • Oct 2007
                        • 613
                        #2921
                        225/45/16 16x8 +17 offset will they fit?
                        • Danny
                          • 14217
                          #2922
                          Any problem using BfGoodrich tires from 2005 production?
                          • RainierHooker
                            • Jul 2009
                            • 2026
                            #2923
                            Just bought new wheels, they are 15x7 ET18. I was planning on using 205/55R15 tires on them. I'm runnig H&R Sports and Billstein Sports on an early model (high arches). These should be fine without any fender rolling or other craziness right?
                            I don't have the wheels in hand yet, but I would like to get some rubber coming so I can get everything together asap...
                            1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
                            • TexasE30
                              • Jan 2009
                              • 298
                              #2924
                              16x9 Et 8,215/40 or 45?
                              16x10 Et 8,225/40 or 35?
                              in another note, 16x7 et 33. They wont fit front without ??mm spacers? 16x8 et 33 in rear?
                              Doesn't mind little poke and little work on fender
                              • Danny
                                • 14217
                                #2925
                                The question stands.
