	This is a sticky topic.
 Wuddup Joey. I'll actually be travelling to your state (medina) to look at and hopefully buy a car on Monday. OT as hell but it's on my mind 24/7.
 To get the Star Specs on, because the offset of those Fittis (see, I remember shit) is pretty conservative you will likely just have to bang in a little bit of metal/plastic on the front. The rear should be okay. Normally I don't recommend the 25" tires but I know you're willing to work for it.Comment
 You would require a minimum of 27mm front spacers to clear the struts safely. In the rear, 20mm would be enough.
 Once you're there, you'd either have to run very stretched tires (205s) with rolled or possibly pulled fender lips or run something larger (225s) with extreme fender pulling or flares.
 Unless this is an all-out auto-x car I probably wouldn't bother. A 15x8 +20 version with a 225 is a lot of contact patch.Comment
 Thanks...would I need fender rolling with the e36 setup?Alex 88 m5 | 91 318is | 19 Subaru Ascent
 BMW Tool Rentals & Fender RollerComment
 In the future I want to run a set of 16x7 O.Z. Ultraleggera on my '87 4dr
 I am running ground control coilovers and billy sports.
 I am mearly asking about what tires I should run and any other bits since I am planning on tucking a TINY bit of tire. Before the rims and tires I am getting GC front camber plates and rear weld in E30tech camber fix. Also doing lug nut stems instead of the short fat headed e30 lugs. Sorry if there is a better word for lug nut stems
 And info about what I should do or get would be grand. Spacer size would be good too.
 P.S. 210-215 in the front and 225 in the rears?http://www.tirerack.com/wheels/Wheel...All&sort=Brand~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
 Instagram: @BWeissLeather
 Current cars:
 ~ '87 325 M30B35 swap
 ~ '87 535
 ~ 01 540 Msport 6spd
 ~ '06 X5 4.8isComment
 So it turns out the wheels are ET35, but I still want to do a 25mm rear and a 20mm front, putting me at ET10 rear and ET15 front. Will I still have to roll (I don't have objection to doing so) the rears ? What about if I run a 205/40/16? Or would I be better off going 25mm all around and putting both ends at ET10?Originally posted by JandersonAlright Jay, here's what I'm planning:
 16x7.5 ACT weaves, they are 5x120, ET30. I'll be running 20mm adapters, putting them at ET10, correct? Will a 205/50/16 fit under there? My front fenders are rolled, rears are not yet, but will be. If that's too much, I have no issue with a little stretch.Comment
 Hi i chose to go with a differant wheel any way what came off was a 15x8 offset -6 what needs to go on is 15x7 offset 20 what size spacers im gonna need please!!!!????
 thanks again!!!Comment
