This is a sticky topic.
I got a set of 16X7.5 wheels, et 20 with a nice 1.5-2" lip I'm dropped on Billys and H&R sports springs but the fronts have RichardKeith 15mm drop hats. I have lightly rolled my rear fenders in the rear but not the fronts since clearance isn't an issue, what do you recommend for a tire size as my DD.@IRON-E30 aka Edwin:DComment
I planning on running an 8mm spacer in the rear on my 15x7 et20 Type A's and was wondering if I would need extended lugs to be able to run that spacer.
I just got flat caps for my Type A's today and just want to know if I would have any issues using them with extended lugs. Thanks
-Kyle
I gots a question. With stock bottle caps and tires on a car dropped about 2.5", how wide spacers can you use without issues?
Also a tad off topic, would it make a huge difference switching to to a bigger wider wheels with a lower profile tire? Obviously that looks better but if theres not a huge difference ill stick with bottle caps.
ThanksComment
I STFA but would still like a confirmation about this setup.
With a 225/45/16 on a 16x9 ET15 square setup fit without any issues?
I have GC coilovers and camber plates.
My 1989 e30 s52 Touring... this is Betty
My 1989 325i vert (sold)...this is Nina
My 1991 M5 (sold)... this is Veronica
Photo comparison: OEM vs aftermarket windscreen for a convertibleComment
Jay,
I've got a set of euroweaves and looking at Ziex 912 225/50/15...I'd like a flush look without any rolling if possible. Camber is at approx. 2.5 in the rear and maybe -.3 in the front, bilstein sports, and H&R sport...do I need spacers front or rear? If so what sizes?Comment
i was looking at the ESM-002r. I have hr race springs and bilsteins on my car now. I want to run 17x8.5(15 offset) in the front and run 17x10(20 offset in the rear). what kind of spacers will i need and tire sizes? I know i will need to roll my fendersComment
No! The offset is far too low and the tires are an inch too tall. You need an offset of 20 at the lowest and tires that are 24.4" or shorter.Friendly Hello to everyone and big thanks to Mystikal for so much great info on wheel fitments. I'm a new guy here and recently picked up an '88 325iX. I would like to use either 16x7 et20 or 16x7.5 et 20 5 bolt wheels on my iX. I will be using 18mm adapters to install the wheels (effectively giving me et2) and 205/55/16 tires. Will this all work on my iX? Thanks!Comment
Stick with 205/50. 205/45 will make your ride height look worse (more gap) plus throw the speedo off more than it is.I just got my ESM002's 16x7.5 et 20. Lowered ~1.6 inches on FK's with rolled fenders. I was set on 205/50/16 G-force sports but now I'm thinking 205/45/16 might be better. Should I stick with the 50's? Any comments on the tires? I wanted to be able to get them at Tire Discounter, these will be daily driver ish tires and for play on streets, not track tires. I just want something with decent treadwear, balance and ~$100/tire. Seemed people on here are OK with them.
Thanks.Comment
Nope. With the E36 suspension those wheels will be poking outside of the fenders. 205/40 is about the biggest you want to go without drastic fender work.haven't visited for awhile. just picked up some 17x8 et20 style 5s with 215/45/17s on them.. will i be able to run these tires for awhile? i'm going to be riding on stock e36 m3 springs so it shouldn't really be lowered at all.. eventually wanting to go coilovers with 235/40Comment
205/50/16.i got a set of 16x7.5 wheels, et 20 with a nice 1.5-2" lip i'm dropped on billys and h&r sports springs but the fronts have richardkeith 15mm drop hats. I have lightly rolled my rear fenders in the rear but not the fronts since clearance isn't an issue, what do you recommend for a tire size as my dd.Comment
