This is a sticky topic.
They will have the same diameter, no issues.89 325i Sedan Bili Sports Eibach Pro's with e90 front hats esm 002 16x7.5 16x9 rear looking at Falken Azenis RT-615 215/45/16 for the rear tires was wondering if these tires are on the front wheel as well if they would like larger than the rear tires due to the 1.5" less width. Thanks in advance!Comment
You will be very, very close to the strut housings without spacers. Do a test fit, if you have more than a few mm you're good.
That said, the tires included are too large to work on a non-M. You're looking at 215/45 or similar (215/40, 205/45, even 225/40) as the 225/45 is just too tall to work with such an aggressive offset and width.Comment
5.25" backspacing will work all around, no spacers. 10s are possible with stretched tires and fender pulling, think 205/50s and 5.75" backspacing. It won't look very good without a lot of additional camber and an extremely low stance though.Comment
Interesting tire size! No, they have no chance of fitting with those tires. Back down o a 205/50 or 215/45 and you're good. 225/45 with a flat fender roll in the back.Comment
Boom:
I'm getting wheels that are 16x7 ET15 front and 16x8 ET20 rear. My car is a '91 318is, that I'll eventually convert to 5x120 via E30 M3 goodies. My question is: Will these will fit on a E30 body with an E30 M3 suspension setup? Will I need to modify/change the offsets much to suit my vehicle?
Hello!
Will 16x8's et10 fit a 1991 318is with a 60/40 kit?
If so which tyres would you suggest?
All the arches have been rolled, although not flared!
ThanksComment
Thank you so much Mystikal! I will share some photos with you if I ever get something together hahaComment
Yes, those will fit perfectly. You will be limited to a 215 rear tire with unrolled fenders, 225 is easy if you roll them.Boom:
I'm getting wheels that are 16x7 ET15 front and 16x8 ET20 rear. My car is a '91 318is, that I'll eventually convert to 5x120 via E30 M3 goodies. My question is: Will these will fit on a E30 body with an E30 M3 suspension setup? Will I need to modify/change the offsets much to suit my vehicle?Comment
