	This is a sticky topic.
You can't stretch anything on a 7" rim unless it's a 165. I'd go 195/55, no spacer needed unless you run into caliper clearance issues.Hey man, I'm bout to pick up a set of bbs Rs 070 et16 15x7's.
I don't really want to roll my fenders.
Will these fit? And what tire should i run to get a stretched look.
I'm running IE 3's and bout to put on billi sports.
(Sorry if someone has already asked but looking through 243 pages is alot of work lol :) )Comment
I recommend 205/50 or 225/45.Hi Jay,
I'm running ESM 002 16" x 7.5" et20 on my 91 318is. I had some 225/50-16 laying around and put those on just to get some use out of them but obviously they are a bit too large. I will be putting on some lowering springs (about a 1.5" drop) shortly and need to change tires before then. Would 215/50-16 work or should I go to with the more standard 205/50-16. Want to have no rub at all if possible.
Thanks,
SethComment
Even without the spacers fender rolling is necessary. So unless you're adding flares or pulling the fenders way way out, no.Comment
What do you mean "flat rear fender lips"? like pulled or do you mean the lip on the lip? haha, the flat lip inside the arch, you mean flatten that against the actual arch? I'm confusing myself trying to explain it.
Forgot to add the style 19s are being redrilled to 4x100, i am not running a 5 lug swap. (if that makes the offset different)
90 325is alpine2 m50b25 becoming a dorifto car.Comment
Thanks man.Originally posted by jasonsnoddyI don't always drift, but when I do, I prefer ford fiestasComment
Thinking of upping my current 215/40 Pzero Nerros on the Kopis (17x7.5, et20) to a 215/45 Continental Extreme DWs for a bit more sidewall compliance. Any issues? I don't currently rub, but shit is pretty low...Comment
Mystikal your the man.
I found some dirt cheap 205/55/16's for my MMII's with spacers. Think it would fit? At least on the front, I'm on Ie3's.
Cheers.Comment
Looking for some advice on my setup.
88' 325i Sedan
KYB's and HR Sports
TRM C1's 15x8
Should I go 225 and if I did would I need any roll on the fenders?
Should I just do 205 to avoid any trouble? (It's just a street car anyways for now)
How much does this all change if I go Vogtland Springs instead of HR?
Thanks!Comment
