	This is a sticky topic.
 Quick question for you guys since you know much more about these cars than I do, especially since I've only had mine a few weeks: What size wheel studs should I order? I have studs on there now (I didn't put them on, so I don't know which ones they are) that worked fine when I was running spacers, but unfortunately I can't get the caps on my DZ1s after removing them. What size/brand should I be looking for?1991 318is - custom dents, loud steering, peeling clear coat, cracked seats. <3 <3
 WTB: Center caps for Zender Sports.Comment
 Thanks for the response! What kind of roll, if any, would I need to put down with that? I forget if I mentioned i'm wearing 205/50. Does it matter if I buy cheap hub rings too, or should I go for the legit gb custom ones?1989 325is / 2.7, 274 cam, e30 M3 5-lug
 1989 LN106 Hilux / 3.0TD SFA
 1974 2002tii / stock
 2002 IS300 / 5spd LSDComment
 I plan on running 14" Basketweaves (14x6.5", ET30) but I want them to be as flush as possible. I already have the fenders pulled to the max so what size spacers should I run front and rear?89' BMW 325is
 Daily Cruiser
 00' Audi B5 Quattro
 Swap! - V6 Biturbo (w/ K04's)
 16x7.5 offset 20 in front, 16x9 offset 15 in back, was thinking 205/45 in front and 215/45 in the rear. Not really a fan of the stretched look, would 225/40 be doable in the rear without rolling the fenders?
 This will be on KYB/Vogtlands, about a 1.5" drop all around.
 Thanks!'86 325es M50Comment
 About to buy some winter tires for a set of bottlecaps I picked up for this winter.
 I recently put on h&r OE sports/billies(w/e90 drophats) and want to know whats a good size tire for winter beater wheels?
 Mostly just want to make sure I wont be rubbing (doubt it will be an issue considering i have considerable wheel gap still.
 185/70? Maybe 185/65?
 Also, recommendations for cheaper-end winter tires would be great. I have been looking at firestone winterforce ones simply because they are cheap and look half-decent.
 Thanks in advanceTbolt Division
 All I'm saying dude is that bird law in this country...it's not governed by reason.Comment
 Help! I'm looking to get a 17x8 and a 17x9 wheel. What size tires for a semi stretched look, and what offset should I be looking for?
 Im lowered on Ground Controls. I want a semi-poke flush look.
 Offsets are killing me! Thanks.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
 Paypal: vdang5@gmail.com
 Delta Auto Care
 2875-C Towerview Road
 Herndon, VA
 703.435.1375
 My Feedback Thread: Evil_TwinComment
 I think I messed up. I'm running the Hartge "Type A" wheels (16x7.5) +10 with spacers all around and was previously running on some Hankook RS2 215/45s?
 I got new tires and they are the Yokohama S Drives in 205/50/16 and I have some rubbing on dips and some fender line rubbing when making full turns. Should I bite the bullet and sell them and get 205/45s or can I make the 50s work. My fenders are rolled but do not know to what extentComment
 got a 16x9 rear et 15 with 10mm spacer in the back (215/40/16)
 for a 16x7.5 et 20 with 10mm spacer up front, what tires would I need? thanks!Comment
 Cheap rings are fine, but if you're planning to see a track get metal ones.
 You should be fine with the 205/50 without rolling.Comment
 Huge ones. 25mm front 30mm rear, and there will still be a little bit of space.Comment
 215/45 will appear less stretched than a 225/40 due to the extra sidewall. Both qill require fender rolling though.16x7.5 offset 20 in front, 16x9 offset 15 in back, was thinking 205/45 in front and 215/45 in the rear. Not really a fan of the stretched look, would 225/40 be doable in the rear without rolling the fenders?
 Thanks!Comment
 185/70 is ideal, but the 65 will do the job. The Winterforce tires are actually quite good.About to buy some winter tires for a set of bottlecaps I picked up for this winter.
 Thanks in advanceComment
