Big change of plans, buy rims AZEV's 4x100, 16 x 7.5 et 20, now I ask which is ideal tire for this rim.
	This is a sticky topic.
 .. so i have to go either S drives or Falken 452 if i go 225-35-17?'89 Delphin 2.8 Cabrio
 '94 Yamaha FZR 600
  Originally posted by FlexdXJIs that thing on air? Originally posted by FlexdXJIs that thing on air?Comment
 Late model E30 on coilover sleeves.
 wheels are 5x120
 16x7.5 front et20
 16x8.5 rear et24
 i was aiming for something flush with little to no poke. anybody know what adapter size I could run? and possible tires? will fender work... work with the rear width?
 (From my post at what is this wheel thread)Last edited by jdirty; 04-12-2012, 09:32 PM.sigpicComment
 Hi Jay,
 I just purchased some stock BBS RM's 15x6.5 ET33. The lips are !/2 inch and I want to put on larger ones. I don't want the wheels to poke out. I was hoping for an E30 recommended tire size of 205/55/15. What size lips and spacer would I have to use? Would I have to use hub rings? I want the best grip and handling is there a different combination that would work better?
 Thanks,
 Tom GouldComment
 Sup my names James i just picked up a set of BBS RZ 469 Style 5 - 5x120 16x8 et23
 what tire profile do you recommend and 5 lug adapter size in mmComment
 205-45 all round with 15/20mm spacers (which i have) and a decent amount of lownessocity.
 GO!
 Edit: didnt see that it was 5 lug... then just get the 18 mm adapters all around. will be easier to sell when it comes time.. and you will still be at et+5 on a 8"... pretty friggin flushLast edited by ToPLeSS(e30)FeinD; 04-14-2012, 10:19 AM.'89 Delphin 2.8 Cabrio
 '94 Yamaha FZR 600
 front 17x8.5 offset 20 center bore 57.1 lip size 3inch
 rear 17x10 offset 15 center bore 57.1 lip size 4inch
 what tire size would be best for this and what would need to be dont?Comment
 OHhhh i hope this is going on an e30... depends on what your final height will be at. if you want to be "stanced", then you need to achieve some stretch, and 215/40 in the front and 225/35 in the rear will do it. ( i dont see why you would put 17x10 final offset 15 on something that wont be low..)
 but if you are going for a casual look, then i suppose a 225/45 front paired with 235/45 rear will look casual enough..
 ya that should be fine. IMO'89 Delphin 2.8 Cabrio
 '94 Yamaha FZR 600
 I just bought 205 50r for my 17x7 wheels will they be meaty?Comment
