	This is a sticky topic.
 You'd have to see what they're rubbing on and if there's room to make space there.I think I messed up. I'm running the Hartge "Type A" wheels (16x7.5) +10 with spacers all around and was previously running on some Hankook RS2 215/45s?
 I got new tires and they are the Yokohama S Drives in 205/50/16 and I have some rubbing on dips and some fender line rubbing when making full turns. Should I bite the bullet and sell them and get 205/45s or can I make the 50s work. My fenders are rolled but do not know to what extentComment
 195/45 would match the sidewall height of the rear, but, well, it's tiny. 205/45 or even another pair of 215/40 would be fine.Comment
 so i took my wheels off this past weekend and found out that they are not rubbing on the fender where it was rolled, but on the inside wheel well directly opposite of where the "flared" part of the rear fender is. I hope that makes sense. At first thought I was thinking of trying to hammer out that certain area but that would only create a bashed up looking fender from the outside.
 I took off my 15mm spacers and there's no rubbing in the rear. However it looks so "sunk" in bc of the high offset (+25). What do I need to do to create that nice stance where the wheel is flush with the fender? Even when I had 215/45 tires I still rubbed on that one side and the wheel wasn't even flush with the outer fender. Any guidance is appreciated. Thanks.
 ps im lowered on hr sport with bilsteinsComment
 You have to do at least one of the following:so i took my wheels off this past weekend and found out that they are not rubbing on the fender where it was rolled, but on the inside wheel well directly opposite of where the "flared" part of the rear fender is. I hope that makes sense. At first thought I was thinking of trying to hammer out that certain area but that would only create a bashed up looking fender from the outside.
 o Get a stiffer suspension (that's one of the softest rear combos made)
 o Not run spacers
 o Get smaller spacers
 o Get smaller tiresComment
 I'd personally go with 25mm adapters and 225/50/15 tires. If you want more of a flush fitment then go 25mm front 30mm rear with 205/50/15 tires.Comment
 Any takers? I'm running no spacers in the rear and 5mm up front (for now) so I just need the smallest that would work so I can get the center caps on.Quick question for you guys since you know much more about these cars than I do, especially since I've only had mine a few weeks: What size wheel studs should I order? I have studs on there now (I didn't put them on, so I don't know which ones they are) that worked fine when I was running spacers, but unfortunately I can't get the caps on my DZ1s after removing them. What size/brand should I be looking for?1991 318is - custom dents, loud steering, peeling clear coat, cracked seats. <3 <3
 WTB: Center caps for Zender Sports.Comment
 I have the typical 16x9 +15 all around set up currently with 215/40 tires. What would my tire size be if I wanted to maximize tire width/a tire size setup for best performance? I hope you understand what I'm trying to ask ahah.2008 335i - n54b30
 1991 318i - m52b28
 1994 fzj80 - LAND CRUSHERComment
 No space for more. Go to a sticky 215/45/16 (Kumho XS, RT-615K).Comment
