	This is a sticky topic.
 No problem, I love to do this for the E30 world.Hey, first and formost, thanks for doing this for the community. Wish there was someone like you when i was buying wheels for my gti.
 Anyways, pretty new to the E30 world and would like to know how these will fit..
 F= 9x17et6
 R= 10x17et19
 I know it will be quite aggressive but the car will be on air, so not to worried about driving, just want to make sure it wont look like a 94 rodeo from south central.
 Thanks,
 Mike
 The fronts are too aggressive. Usually people match 17x10 +20 rears (typical setup for very aggressive E30s) with 17x8.5 +20 or +13 fronts, and they're still VERY aggressive. Your setup will only work with 3+ degrees of camber, and it'll be a bit of trial and error. Pull it off properly and it would be epic.
 205/40 front and 225/35 rear would be my choice.Comment
 Totally depends on how willing you are to use that roller. It's already almost maxed out. I'd say 5mm front 10mm rear with a very aggressive roll/pull, but again, you have to be willing to really push it.Comment
 I prefer 205/45 (slightly taller, gives more oil pan clearance and fills up more fore/aft wheel gap) but 215/40 is adequate.wow....250 pages of pure fitment hahahah this is awesome.
 borbet b's 16x9 et 15 on all four corners with 215/40r16's
 what kind of tires(if current ones are not adequate) do you recommend and what size spacers?
 i am trying to go as wide as i can without pulling(fenders are rolled) and as low as possible ;)
 5mm front 10mm rear spacers is about the max for unpulled arches.Comment
 205/45 for sure.Going to be running 16x8 et20 all around, just wondering if i should run a 205/40 or a 205/45?
 My car is really low now, tucking tire, however i have a B+G "lowering" suspension setup i will be putting on (which will raise the car up) and im on the fence if i should run a 205/45 to minimize wheel gap?
 I am going to order some new tires in the next few days. I am looking at 205/60/14's.
 Should I be looking at 195/60/14's instead?
 From reading this thread I am pretty much set on the Yokohama AVS ES100's in a 205/195. Where should I buy? I am looking at tirerack.
 TIA
 -BenLast edited by Miasma; 10-18-2010, 07:47 PM.Comment
 16x7 with a +6 offset and 16x8 with a +18 offset, looking to go with coilovers and thinking 205/40/16s.
 late model 318is - ballpark if I cam make this work or go back to drawing board
 Thanks.Comment
 The 16x8 only comes in 0 offset, meaning it will not fit an E30 properly. The 17x9 does not come in 4x100 from what I can see. The 16x7 comes in a proper +25, but it won't be anywhere near flush on our cars.Comment
 Looking at Tirerack, for the price of that 205/60 ES100 you could have a 195/60 Dunlop Z1. The Dunlop is leagues ahead of the ES100 in just about every aspect (it's one of the best tires made today, while the Yokohama is almost a decade old and out of production).I am going to order some new tires in the next few days. I am looking at 205/60/14's.
 TIA
 -BenComment
 Nice, I'd go with 205/45 though (the 40s will be far too short, the car will look strange from the side).Comment
