This is a sticky topic.
I have an 89 325ic right now I have 14x6.5 with a 30 mm offset
I want to put on 1989 15x7 ix wheels with a 41 offset
so my inner clearance will be 17mm less (the inside of the wheel to the strut housing)
and my outer position will retract by 5mm
Outer Position: (position of the outside edge of the wheel
what does this mean as far as spacers go? and also what kind of lugs will i need?
thanks in advance! I have searched like crazy and have not found a real clear answer other than 15 mm spacers but if I dont need them than I'd rather not run them...My Multi car part out. Need a part? Pm me...
http://www.r3vlimited.com/board/showthread.php?t=193051
Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
http://www.r3vlimited.com/board/showthread.php?t=215044
Have you done business with me? If so leave me feedback here...
http://www.r3vlimited.com/board/showthread.php?t=188307
having a problem with my rims... i got 16x7 ET25s with 205-50/16 tires. am i over-tired? i have rubbing issues at full lock. i'm lowered on some H&R springs
thanks in advance! I have searched like crazy and have not found a real clear answer other than 15 mm spacers but if I dont need them than I'd rather not run them...Comment
yup - is that what's causing the problem? i'm also running on H&R sport springs, but that's only supposed to drop by 1.25". shocks are bilstein HDs.
thinking of picking up a set of borbet t's in size 16x7.5 with tire size 195/45/16 does anyone know if these will rub i'll be running vogtland springs in a week on my E30 vert. I have to drive a good distance to get these so just trying to make sure before I drive so far. The seller claims I don't need spacers or anything they just bolt up is this true anyone have any experience with these wheels? I'm just trying to save myself a headache if they didnt work out.. thanks for all the help.My Multi car part out. Need a part? Pm me...
Enkei 15x7 spacers?
I am thinking of running Enkei RPF1 15x7 ET 35 (they are also available in ET 41) on my M30 89 vert running M3 springs. I expect to run a 225/50/15 tire. I am trying to decide on spacer thickness and am guessing 10 mm front and back putting the ET at 25. Would this plan work well? Maybe it would it be better to go a little wider in the rear? I don't want to roll my fenders. What do you think?Never argue with stupid people, they will drag you down to their level and beat you with experience. -Mark TwainComment
thinking of picking up a set of borbet t's in size 16x7.5 with tire size 195/45/16 does anyone know if these will rub i'll be running vogtland springs in a week on my E30 vert. I have to drive a good distance to get these so just trying to make sure before I drive so far. The seller claims I don't need spacers or anything they just bolt up is this true anyone have any experience with these wheels? I'm just trying to save myself a headache if they didnt work out.. thanks for all the help.Comment
I am thinking of running Enkei RPF1 15x7 ET 35 (they are also available in ET 41) on my M30 89 vert running M3 springs. I expect to run a 225/50/15 tire. I am trying to decide on spacer thickness and am guessing 10 mm front and back putting the ET at 25. Would this plan work well? Maybe it would it be better to go a little wider in the rear? I don't want to roll my fenders. What do you think?Comment
I have a set of nearly new 205/55-15 Bridgestone Potenza S0-3 Pole Position's... got em fo FREEEEEEEEE!!!!!
I want a set of 15x6 corrado steelies but people are holding onto those for dear life. A new set is $260 shipped, but figured id look for something cheaper during the winter.
Originally posted by vladDo you know anybody else who built that many bad ass E30s?Comment
