This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #3751
    Originally posted by mkcman17
    I just bought a set of maxxim lemans 16x7.5 et35. Yes, 35. The centerbore is larger too. Right now, they'll rub on my front struts. I'm thinking of running 10mm up front and 15 mm rear in terms of spacers. Can I simply get custom hubcentric spacers or do I need to buy the rings too?
    I'd go with off the shelf spacers and hubcentric rings combined. This way you can reuse or sell the spacers later, easily.
    I'd recommend 15mm front 20mm rear.
    • Mystikal
      • 9602
      #3752
      Originally posted by FKNFASTM5
      Hey, first and formost, thanks for doing this for the community. Wish there was someone like you when i was buying wheels for my gti.
      Anyways, pretty new to the E30 world and would like to know how these will fit..
      F= 9x17et6
      R= 10x17et19
      I know it will be quite aggressive but the car will be on air, so not to worried about driving, just want to make sure it wont look like a 94 rodeo from south central.
      Thanks,
      Mike
      No problem, I love to do this for the E30 world.
      The fronts are too aggressive. Usually people match 17x10 +20 rears (typical setup for very aggressive E30s) with 17x8.5 +20 or +13 fronts, and they're still VERY aggressive. Your setup will only work with 3+ degrees of camber, and it'll be a bit of trial and error. Pull it off properly and it would be epic.
      205/40 front and 225/35 rear would be my choice.
      • Mystikal
        • 9602
        #3753
        Originally posted by IRUNEDM
        I got 16x8 +20 rims and 225/40-16 tires. How big of a spacer will I need to make it more flush. I'm on H&R Race with Bilstein HD. I also have access to a fender roller. Thanks in advance!
        Totally depends on how willing you are to use that roller. It's already almost maxed out. I'd say 5mm front 10mm rear with a very aggressive roll/pull, but again, you have to be willing to really push it.
        • Mystikal
          • 9602
          #3754
          Originally posted by charlescho
          wow....250 pages of pure fitment hahahah this is awesome.
          borbet b's 16x9 et 15 on all four corners with 215/40r16's
          what kind of tires(if current ones are not adequate) do you recommend and what size spacers?
          i am trying to go as wide as i can without pulling(fenders are rolled) and as low as possible ;)
          I prefer 205/45 (slightly taller, gives more oil pan clearance and fills up more fore/aft wheel gap) but 215/40 is adequate.
          5mm front 10mm rear spacers is about the max for unpulled arches.
          • Mystikal
            • 9602
            #3755
            Originally posted by e30shmobberr
            what does et25 or et15 or any et mean?
            Offset. See the first post.
            • Mystikal
              • 9602
              #3756
              Originally posted by e30lov
              Going to be running 16x8 et20 all around, just wondering if i should run a 205/40 or a 205/45?
              My car is really low now, tucking tire, however i have a B+G "lowering" suspension setup i will be putting on (which will raise the car up) and im on the fence if i should run a 205/45 to minimize wheel gap?
              205/45 for sure.
              • dazz822
                • 1
                #3757
                If i was to get xxr 522's 16x8 would i be able to fix and be flush without a roll? What offset and tire should i use? Could i fit 17x9's in rear? If i could a may do a 16x7 in front but not sure interested in what you think.
                • T La
                  • Dec 2009
                  • 190
                  #3758
                  Originally posted by Mystikal
                  20 front 25 rear, and keep the 205/55s.
                  sweet, thanks. that probably wouldn't require a roll right?
                  • Miasma
                    • Apr 2007
                    • 2009
                    #3759
                    I am going to order some new tires in the next few days. I am looking at 205/60/14's.
                    Should I be looking at 195/60/14's instead?
                    From reading this thread I am pretty much set on the Yokohama AVS ES100's in a 205/195. Where should I buy? I am looking at tirerack.
                    TIA
                    -Ben
                    • DrFraserCrane
                      • 605
                      #3760
                      16x7 with a +6 offset and 16x8 with a +18 offset, looking to go with coilovers and thinking 205/40/16s.
                      late model 318is - ballpark if I cam make this work or go back to drawing board
                      Thanks.
                      • Mystikal
                        • 9602
                        #3761
                        The 16x8 only comes in 0 offset, meaning it will not fit an E30 properly. The 17x9 does not come in 4x100 from what I can see. The 16x7 comes in a proper +25, but it won't be anywhere near flush on our cars.
                        • Mystikal
                          • 9602
                          #3762
                          Correct, shouldn't need a roll.
                          • Mystikal
                            • 9602
                            #3763
                            TIA
                            -Ben
                            Looking at Tirerack, for the price of that 205/60 ES100 you could have a 195/60 Dunlop Z1. The Dunlop is leagues ahead of the ES100 in just about every aspect (it's one of the best tires made today, while the Yokohama is almost a decade old and out of production).
                            • Mystikal
                              • 9602
                              #3764
                              Thanks.
                              Nice, I'd go with 205/45 though (the 40s will be far too short, the car will look strange from the side).
                              • DrFraserCrane
                                • 605
                                #3765
                                good deal. thanks
