Looking to pick up a set of esm 002's 16x9 all around. From what i've read i should go et10 all around to avoid spacers right? Suspension is GC with camber plates up front. Just trying to make sure i get the right offset and tire size. Thinking 215/40, is 215/45 to big? Fenders are rolled a little, car used to have a 16x9's at one point when the previous owner had it and the tires were 215/40, just wanted to see if the jump to 215/45 would cause rubbing. Don't mind a little stretch, but i'd prefer a little more tire. Thanks!!
	This is a sticky topic.
 1991 318is S52
 1987 325i Vert
 1991 325i
 2011 e70 X5
 Need Anything E30? -> http://www.gutenparts.com/
 Yup, I had told ESM to make them +10 instead of +15 so that they clear the struts without spacers. 215/45 has been done, but definitely requires more fender rolling in the rear than the standard 205/45 or 215/40.Looking to pick up a set of esm 002's 16x9 all around. From what i've read i should go et10 all around to avoid spacers right? Suspension is GC with camber plates up front. Just trying to make sure i get the right offset and tire size. Thinking 215/40, is 215/45 to big? Fenders are rolled a little, car used to have a 16x9's at one point when the previous owner had it and the tires were 215/40, just wanted to see if the jump to 215/45 would cause rubbing. Don't mind a little stretch, but i'd prefer a little more tire. Thanks!!Comment
 BBS rs 16x7.5 et 30 front and rear. With 17mm adapters, brings offset down to et 13 front and rear. HR race springs on an mtechnic convertible... maybe 205 50 16 tires or 225 45 16?Comment
 So what should i go with the 205/45 or 215/40? I'll def adjust the front camber so they tuck better.sigpic
 1991 318is S52
 1987 325i Vert
 1991 325i
 2011 e70 X5
 Need Anything E30? -> http://www.gutenparts.com/Comment
 Jay, how about the wheel fitment in a e30 m3?
 17x8.5 et 30 front
 17x9.5 et 20 rear
 For the front do you think I would need spacers? How's for the back? Will stick out a bit of the fender?
 Also for tires, what size would you recomend. I can't run short height tires due the potholes, bumpstos, cracked roads down here, but of corse wont' run hghe side wall tires.
 ThanksEuro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
 You'll definitely need a spacer up front to clear the calipers and you will most likely rub on the suspension in the rear as well, especially if you don't want to run stretched tires. The wheels won't stick out on the rear past the fender. I run 17x10 ET19 with a 5mm spacer to make it ET14 on the rear and I'm just about even with the fender. But then again, I have slightly stretched tires.Jay, how about the wheel fitment in a e30 m3?
 17x8.5 et 30 front
 17x9.5 et 20 rear
 ThanksComment
 Even with the 205s a fender roll would be required in the rear. 205/45 would work without any fender work though.Comment
