So I suppose its just more of a general idea. Thanks for the clarification though.
	This is a sticky topic.
 i have an 89 325i. i picked up 15x7 ix weaves. i was thinking of running 20mm spacers all around. my fenders are already rolled. my question to you is; what size tire would be better with this set up? 205 50 15, or a streched 195 50 15.
 im on bilstein sport suspensionLast edited by LancE30; 01-18-2011, 04:28 PM.Comment
 I'm looking for widest tire on an early(86) 325e sedan(large arch) with 16x8 et20 and 5mm spacers or any size spacer that brings me biggest tire fitment, I have no problem on rolling or pulling fenders.
 On suspension it has billy sports with H&R 1.5 drop front and 1.3 back...Comment
 I just purchased a set of style 5's (were re-drilled to 4x100) 16x8 et23 all around, with 3mm spacers in the front (barely rubbing caliper, might to shave a bit off)
 What tires would you recommend? 205/45-16? 215? 225? Fender rolling/pulling will be done if I have to.1990 Alpinweiss 325i - secret 500whp buildOriginally posted by audiquattrotbimmers b4 b*tches....remember that.
 2000 Audi S4 B5 Laser Red
 1990 Nissan 240sx - Drift Missile
 2006 CBR600RR
 Im wondering for my setup if using those 20mm 4x100 to 5x120 adapters will work to put these on an early body, or is there 15mm adapters available to convert 4 to 5 I only found the 20mm ones? its only temporarily and im running stock suspension but will lower later and maybe convert to five lug but if this works and can be lowered to help it, I might not do the 5 lug conversion just the adapters and the drop then. will 17x8.5 ET41 or 17x8.5 ET13 work in the front and 17x10 ET15 work in the rear? if fender rolling has to happen Ill do it which im assuming. also if I cant get the 17x10s I was just gonna run 17x8.5 all around what would be needed to do that also? what size tire to run, the stretched look is fine with me aswell, what ever is takes to stuff these under there as long as they look good. oh and if just do the five lug in the back then Im assuming since that 20mm adapter wouldnt be there, that would give me 20mm to work with in the back, would that help to put those 17x10s in the rear? thanksComment
 I am looking to run DS1 17x7.5 wheels (et40?) with 20mm adapters on my 91 vert. Would this work without fender rolling? If so what size tires would be necessary? Not a huge fan of stretched tires, so I don't mind rolling if I have to.
 ThanksComment
 They'll fit, but I know zero about those tires.Hoosier has a sale on 205/65/14 'HISTORIC RADIAL DOT SPEEDSTER' tires. If I put them on stock weaves, it's cool, right? I don't know how they do on actual mounted tire width, but my understanding is wider than the average tire.
 That said, those are track tires, yes? If not, that would defeat the purpose.Comment
 With 225s, there isn't much space left. Any more than a 3mm in the rear will need fender rolling. If you're willing to roll heavily, 10mm is possible.Comment
 Depends what your priorities are. If you want even tire fitment, then yeah go staggered. If you want neutral handling, 225s x4.Just put new lips on my schmits 8.5" rear and 7.5" front I calculated the offsets to be about an et 22 front and rear ( i may be off a mm or 2) .My fenders will be rolled and im lowered on race springs.Would it be better to go 215 45 up front and 225 45 in the rear or 225 45 all around?
 thanksComment
