	This is a sticky topic.
 No, they won't work well at that offset (assuming you mean 17x8 +20 E39 Style 5s).Comment
 I live in Calif and won't be driving the car very much in the rain. I don't want a super soft tire but I don't need to get 40K miles out of them either. A tire that feels the road and is fun to drive is my goal. Hope this helps. I would like to keep the price per tire under $150 if possible but if the best tire for my needs is slightly over that price it would be ok.
 Cheers,
 JimsigpicComment
 We're referring to the 205/50, right?I live in Calif and won't be driving the car very much in the rain. I don't want a super soft tire but I don't need to get 40K miles out of them either. A tire that feels the road and is fun to drive is my goal. Hope this helps. I would like to keep the price per tire under $150 if possible but if the best tire for my needs is slightly over that price it would be ok.
 Cheers,
 Jim
 With your dry traction and response goals you will have to sacrifice treadwear. Around 15-20k can be expected. You can offset this by purchasing one of the less expensive options: Falken RT-615K, Hankook R-S3, Kumho XS. All of these are phenomenal and will pretty much transform any E30.Comment
 Rear fenders will have to be pulled, fronts a flat roll. Car will also need to be much, much lower than H&Rs to pull off that setup. 205/50 all around.Comment
 Yes, and thank you for your input.We're referring to the 205/50, right?
 Cheers,
 JimsigpicComment
 Jim also check into NITTO NEO-GENS' 205/50/15 HR/VR. 15-20K These tires worked bitchin for me daily driving to work and canyon spirited driving.
 Terry.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
 garage queen 91 bmw 325is / 1972 Chevy El Camino 355 sbc 450hpComment
 I've got a set of 15x7, 40mm offset Team Dynamics Pro Race 1 wheels I want to use on my '91 318is. I've got 3 sets for my MINI (2006 R53) and would like to be able to get a little crossover between the vehicles in my household. :D I currently have basketweaves and finding suitable tires for the track in 14" looks to be an almost impossible task. 15" isn't all that much better, honestly…
 I did some test fitting on the driver's side front with the new Dunlop DZ101 tire I got for my MINI yesterday. 205/55-15. I cobbled together a 6mm spacer from some aluminum and it still wasn't enough to clear the strut, so I think I need at least a 10mm spacer. I haven't tried the back, yet. If I can keep this thing running long enough, I may end up running dedicated track tires, in which case I'd probably go as wide as 225.
 The car's been lowered by the previous owner; it's on Bilstein shocks, H&R springs (I think). I don't know how much it's been lowered, but it's not obscene. It's on 205/60-14 Yokohama ES100s right now.
 The wheels have a 73.1mm centerbore, so I need to use centering rings.
 What spacers do I need to get these wheels to fit with 205 (and ideally 225) rubber? What length lug bolt do I need?Comment
 Hey J,
 Im looking for a little more info on fitting a 225/50 on a 15x8 et 20(trm c1)..
 How much fender work is needed? Im already rolled and slightly pulled all around. Im on coilovers and have camber plates in the front.... Because I know some brands might be wider or not.. Im specifically looking at the g-force sport in that size...
 Thanks man,
 AndrewComment
