This is a sticky topic.
55mm is sufficient. 60mm should work also.I got my style 5's filled and redrilled, running 205/45/16 in the front and 205/50/16 in the rear. I got a great deal on the rear wheels that I couldn't pass up. For some reason the 5mm spacers I got for the front did not clear my brake carriers, so I am getting 8mm spacers for the front and 10mm spacers for the rear. Both front and rear fenders will be receiving a mild-medium roll.
My question is about what length stud kit I can run and still be able to use the style 5 caps.Comment
Not sure if they need more spacing for caliper clearance or tuner lugs (doubt it), maybe search the forum and ask owners of that wheel.Comment
Thanks for the response. Just wondering if anyone has tried 205/70r14 or not and what problems they had. I don't mind a bit of rubbing as long as it's only under hard cornering and braking etc.Comment
Would 17x8.5 offset 40 wheels fit on an E30 with a 5-lug conversion from an E30 M3? If so, what size tires would be recommended?Comment
What tire would you recommend in 225/50/15 I really won't see any track time just throwing it around the twisties around nm. I'm on JOM coilovers too. The wheels are 15x7 OZ fittipaldi indy'sComment
Does anyone know if the BBS Euroweave wheel 7 X 15 4 X 100 ET24 will fit on the 325IX which has a BBS 15" wheel with ET41 offset?91 E30 318is DS/Anthrazit S14 & 5 bolt
99 E36 M3 Cosmos/black leather
06 E90 330i Black Sapphire/black vinyl stuff
WTB: Black 71-76 2002
www.bcbimmers.comComment
I have some gti/Cabriolet 14x6 Snowflakes that are et38 and want to know if I can run them without many issues. I know the offset is 3mm more to the inside of the tire and as it sits there is only about half of an inch difference. Also what do I do about the conical vs. tapered lugs. The e30 has tapered and the VW wheels are conical so can I use the vw lugs on the e30?
