This is a sticky topic.
I have been trying to figure out if I can get some 17" x 7" with 40mm offset with some 225/45r17s to fit on my 318is. The car is sitting on h&r sports with bilstein sports. I called the tire store here and I was told I would need like a 12mm spacer to fit. Can I run these without spacers or will they and longer stud bolts be needed? Here is a link to the rims I am looking at buying. They are konig ultralights
Diamond Steelies Question.
I would like to have these steelies made for my car with these specs: 4x100, to fit 91 E30, 16x7, and I want to run 225/45/16 tires. What offset would i need to make this work. I have H&R race with Bilstein sports. Any help would be appreciated. Thanks......................G.Comment
I currently have an '87 325ES with a 5-lug conversion from an E30 M3. It is currently running E36 DS1 wheels with 235/40 R17's all around. I found a pretty good deal on some BBS's, but I'm not sure that they will fit. The wheels I'm looking at are 17x8 in the front and 17x9 in the back. They have 225/45's in the front and 245/40's in the back. The offset is ET40, and the seller ran them on an E46. I know it would be a tight fit, but would these fit on without any serious fender modifications and/or rubbing, or are these just entirely too big for an E30?
Thanks in advance!Comment
I'm having some 16x8 style 5's redrilled in LA, I was planning on running 5mm spacers in the front for clearance and 10mm hub-centric spacers in the rear for flushness ;)
Two questions:
1. What is the largest size tire I can run without rubbing?
2. I know the 5mm will make me flush in the front, or actually even poke a bit. I was wondering if 10mm too big to get flush in the rear and how much will I need to roll my fenders.
I'm dropped on JOM coilovers with no adjusters or spring pads in the rear.Last edited by blck325is; 04-06-2011, 08:21 AM.Originally posted by csermonet47Vlad, you are handling this quite unprofessionally.
Also, you are a cock with tacky taste.
That is all.Comment
Hi guys. I just sold my 16x7 Alpinas :( and I'm in the market for new wheels. I found some 4x100 Rotiform BLQs which are 17x8 et20. Any idea how hard it would be to fit these? What tires should I use?
I am dropped on eibach pro kits with billy sports.-1988 BMW 325is - Sold
-1991 BMW 535i - Parted out
-1994 BMW 530i/5 - Sold
-1970 Chevy C10/LWB
-1973 Chevy C10/SWB stepside
-1984 Chevy C10/LWB
-2008 R56 MCS - Dead
-2018 Toyota Tacoma TRD-OR DCLBComment
wanting to fit my style 5's (e38) 16x8 et 23 + 5mm spacers = et18 overall under a stock suspension late model vert -1991- will 225/50/16 give me any issues ? Ive read that they will destroy fenders but most of those threads were about lowered cars. I might put a drop hat up front eventually, but for now shes going to stay stock.[sigpicComment
+25, give or take 3mm.Diamond Steelies Question.
The setup will only work with wheel spacers and smaller tires.I currently have an '87 325ES with a 5-lug conversion from an E30 M3. It is currently running E36 DS1 wheels with 235/40 R17's all around. I found a pretty good deal on some BBS's, but I'm not sure that they will fit. The wheels I'm looking at are 17x8 in the front and 17x9 in the back. They have 225/45's in the front and 245/40's in the back. The offset is ET40, and the seller ran them on an E46. I know it would be a tight fit, but would these fit on without any serious fender modifications and/or rubbing, or are these just entirely too big for an E30?
205/45/16 is the limit without fender rolling. 215/45 is possible with a roll. These are both assuming 10mm spacers, which are a good idea to match the front.I'm having some 16x8 style 5's redrilled in LA, I was planning on running 5mm spacers in the front for clearance and 10mm hub-centric spacers in the rear for flushness ;)
Two questions:
I'm dropped on JOM coilovers with no adjusters or spring pads in the rear.Comment
215/40/17 would be perfect.Comment
205/45 is your limit without fender modification.wanting to fit my style 5's (e38) 16x8 et 23 + 5mm spacers = et18 overall under a stock suspension late model vert -1991- will 225/50/16 give me any issues ? Ive read that they will destroy fenders but most of those threads were about lowered cars. I might put a drop hat up front eventually, but for now shes going to stay stock.Comment
whoa !!! so with 225/45/16's with both front and rear fenders need rolling ? 205/45's will be too much stretch for me.[sigpicComment
Thinking about the Dunlop Star Spec in a 205-50 - or the Falken Ziex 912 in a 205-45 ? Thoughts ? How concerned should I be in the rear with an et 30 offset ?Last edited by ruqknuf; 04-06-2011, 01:53 PM.Comment
-1970 Chevy C10/LWB
-1984 Chevy C10/LWB
