	This is a sticky topic.
 Hi Mystikal,
 please help for tire fitment
 Car: 1991 BMW e30 m40
 S/A : Bilstein
 Lowering Spring : Jammex Sport-kit
 Rims # 01: BBS RS023
 (Original set 8x16 et.24 - 1.5" lip, 6" barrel)
 already change to;
 - front 7.5 x 16 (change original barrel to 5.5")
 offset change to et.18 (plc cmiiw.. )
 - rear 9 x 16 (change original lip to 2.5")
 offset change to et.11 (plc cmiiw.. )
 ? please info what tyre is suitable for this set
 Rims # 02: BBS RS071
 Original set 8x15 et.18 - 2" lip, 5.5" barrel
 but i found this rims is change to 6.5x15 et.37(?) - 0.5" lip, 5.5" barrel
 i want to change the lip, can you help me suggest what lip to choose if i want staggered look for daily use ?
 is it 1.5" front and 2" rear or 1.5" front and 2.5" rear ?
 also what tyre to fit the setting ?
 Thank youComment
 What size adapter/tire size should I run for Corvette salad shooters on a late model e30, if I'm shooting for a flush fit. I've seen varying setups so I wanted your opinion.
 I will be running GC coils as well. I'm not afraid to roll my fenders either as long as its not a ridiculous amount.
 PCD: 5x120.65
 16x8.5 et32
 16x9.5 et38Comment
 so just to be sure 17"x11" et-25 has the same backspacing as stock "Is" basket weaves( or very close to), so Ill have the same clearance as the stock wheel to caliper correct?
 Will this fit with some big fender flairs?sigpicComment
 205/45 front 225/40 rear. Rolled rear arches. If you're worried about fender work 195/45 front 215/40 rear.Hi Mystikal,
 S/A : Bilstein
 already change to;
 1.5" front 2.5" rear is nice. It's tough to find tires the right diameter for an even stretch though, I'd suggest 195/50 front 205/50 rear for something close.Rims # 02: BBS RS071
 Thank youComment
 20mm front 25mm rear. 195/45 and 215/40 or 205/45 and 225/40 depending on your desired amount of stretch and willingness to work a roller.What size adapter/tire size should I run for Corvette salad shooters on a late model e30, if I'm shooting for a flush fit. I've seen varying setups so I wanted your opinion.
 PCD: 5x120.65
 16x8.5 et32
 16x9.5 et38Comment
 8mm spacers can be trouble on an E30 as the wheel would have zero or next to zero hub lip to sit on. On the rear though, you'll probably get away with it. Learn to torque the bolts in the proper star pattern prior to lowering the car down and you can lessen/avoid any wobbles.
 the wheels are 17x8 et 25 do you think it would still be an issue? i heard this specific wheel is not ideal to run a spacer with that size?Comment
 Wheels: Azev A - et20 16x7.5
 Tire Desired: N.A
 Tire Size: N.A
 Suspension: H&R Sport / Bilstein Sport
 Chassis: 88 325is
 I'm inquring about 225/45/16 size tires. Will there be rubbing of any kind? Body is all stock, fenders never rolled. Better bet to go 205/50/16? Mainly for daily driving & hard parking. :D
 Hi Mystical,Rims # 02: BBS RS071
 thank u for this advice,
 For my consideration please info if:
 - the front lip change to 2" lip (=> r15x8 et.18)
 - and the rear with 2.5" lip (=> r15x8.5 et.12)
 Please advice the tire fitment
 Thank you..Comment
 Hi,
 Have a set of staggered BBS RS
 RS001 15x7 and
 RS002 15x8
 What tire size should I run ?
 Same all around ? Wider in rear?
 Will 17"x11" et-25 have any clearance issues with the insides of the car. Am I correct in assuming that the et-25 on an 11" wide wheel is the same back spacing as a stock wheel?
 which is roughly 5" correct?sigpicComment
