	This is a sticky topic.
 Offset /= Brake clearance
 You'll need a template (usually a .pdf) from the brake manufacturer to know for sure what fits.Comment
 It's possible with a 195/45 or 205/40 and a flat fender roll all around. May need additional front camber (plates, crash mounts) if you're very low.Comment
 Without fender pulling/flaring, it's not possible. If you plan to do it you'll have to mount them to see how much space you need to create before starting to roll/pull/section. It's not going to work with the stock arch line.At a guess I would say they would get pushed way out of the arches when using adapter as they normally are quite thick (20-25mm?).
 Anyone run 16x9 et15 with 225/45/16's? Looking at a tyre size calc these are close to stock 205/55/15's. I can do what ever work is required before resprayComment
 I'm assuming this is for a non-iX non-M3 non-5lug E30.
 16x8 +20
 205/50 or
 215/45 or
 225/45Comment
 You only need a fender roll to fit 235s all around. A small pull for 245s (and added front camber, which I assume you have if you're drifting).245/40-17 or 235/40-17 on a 17x8.25 with ET20.
 E30 M3 Front/rear fiberglass quarters. Possible? I can "space" the rear fender out if I need to. I know I'm running into the issue of the tires being oversized (diameter), but it's a track/drift car. What size spacer would you recommend, if any?Comment
 I am looking into rubber for a set of wheels I have. I do not know what is a proper tire size that is good with the s50, any ideas? Wheels are 16x7 et37 and I'll be running 10mm spacer front and rear. Also I don't know how far the wheels will sit, anyone have a close setup that I can see photos of? Thanks in advance, my wheel/tire knowledge isn't great
 Patrick - IG:niicknac
 RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
 You can fit up to a 225/45/16 with that setup. There are no great tires in that size any longer though, so look at 215/45 and 205/50.I am looking into rubber for a set of wheels I have. I do not know what is a proper tire size that is good with the s50, any ideas? Wheels are 16x7 et37 and I'll be running 10mm spacer front and rear. Also I don't know how far the wheels will sit, anyone have a close setup that I can see photos of? Thanks in advance, my wheel/tire knowledge isn't greatComment
