This is a sticky topic.
  • navid41691
    • Apr 2011
    • 677
    #5236
    Does anyone see a problem with fitting a 195/40/17 tire on my bbs rc090's? aka style 5's.
    • - jay
      • 343
      #5237
      16x9.5 et38 all around.
      Reccommended Tire and Adapter sizes? I know I'm going to need fender work as well. Thats were Tony comes in. ;)
      • SLEEPYDUB
        • 658
        #5238
        Mystical, thanks for creating this thread.
        Im sure this has been asked before, but I need to know the the tire size for my needs.
        I am going to need the MOST contact patch I can get for the front as i will be drifting. Borbet Type As, 16x9 et15 all around. Can you suggest a front tire that will give me the most surface area for the front and the back? I will also be on BC Racing coilovers, and im sure ill have to use a 5mm spacer or so.
        I was thinking 225/45/16 would give me the most width without the tire being too tall?
        Thanks!
        - AXIS POWERS - 2JZ E30 Build
        Current Project - 87 325is 2JZ Swapped with M4 DCT
        • knuklehead92
          • Aug 2011
          • 732
          #5239
          The general style discussion forum, as well as a place to post your car, or any car for that matter.
          i am thinking about following this guys wheel specs
          ccw lm20s
          17x9.5 +3 fronts and 17x10.5 +12
          but with propper tire fittment and fender flares no streched tires.
          he put these on a later model e30
          would it fit a 1987 model e30
          are the wheel arcs different in rear? i heard but want to confirm.
          Trust me it stock :yawn:
          • - jay
            • 343
            #5240
            yeah early rear arches are higher...
            • bubbajan21
              • 1962
              #5241
              Late model E30, Full E30 M3 5-lug conversion.
              I'd like to run a set of 17x8 ET20 wheels. I'm thinking 235/40 R17 up front and I'd like to fit 245/40 R17's in back. Does this seem doable? What kind of spacers / fender rolling would be required? This car will be getting painted so now would be the perfect time to be rolling and pulling if it will be required. Are 245's in the back doable or are they just too big to stuff under this late E30?
              • mkcman17
                • Jul 2010
                • 8240
                #5242
                trying to see if i can run adapters on a set of unknown spec wheels. they're somewhere near 16x7 et10, if my measurements hold up. this picture is with 8mm of space, would need at least 10mm more to run an adapter. realistic or pipe dream? i have camber plates max'd out in picture.
                1989 LN106 Hilux / 3.0TD SFA
                1974 2002tii / stock
                2002 IS300 / 5spd LSD
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  #5243
                  Originally posted by FunfGan
                  Thanks! My thoughts exactly on spacers, I wanted to use as small as one to get by. And by trailing arm grinding, do you mean the pinch weld that sticks out a bit?
                  Yes, that ugly weld. Just a bit of material from it should be enough, hopefully.
                  • Mystikal
                    • 9602
                    #5244
                    Originally posted by wildstoats
                    Ok, after much waffling I finally obtained a set of wheels that I'm going to try out and I need some advice on spacers.
                    16x7 - Offset: +30
                    Late body style car, lowered on Ground Controls, camber plates, etc. I'm going to be running a 205/50 Star Spec. Looking for the most aggressive fitment I can pull off with rolling only. Thanks again, hopefully now you won't hear from me for a while.
                    15mm all around.
                    • Mystikal
                      • 9602
                      #5245
                      Check the tire's load rating first. 80 is about the bare minimum I'd suggest on an E30 (and it still isn't safe, technically).
                      • Mystikal
                        • 9602
                        #5246
                        You'll need 33mm front adapters to clear the struts, and I'd suggest 225/40 rubber. Work the rest of the details from there if you can.
                        • Mystikal
                          • 9602
                          #5247
                          Thanks!
                          225/45 will work with a bit of fender massaging and lots of camber (which I assume you already have going on on a drift car). Unsure of BC Racing strut clearance on an E30, I have an 8K/12K set waiting for a customer car now and can't wait to see if his 16x9s will clear without spacers. On all other BMW platforms BC's add a whole whack of clearance compared to OEM or most other brand coils.
                          • Mystikal
                            • 9602
                            #5248
                            Originally posted by knuklehead92
                            http://www.stanceworks.com/forums/sh...ad.php?t=11988
                            ccw lm20s
                            17x8 +20 215/40
                            17x9 +28 235/40 or 245/35 (fender roll needed)
                            • Mystikal
                              • 9602
                              #5249
                              Even the 235s are difficult to fit without rubbing. 215/40 is the recommended size.
                              • Mystikal
                                • 9602
                                #5250
                                Theoretical 16x7 -8? It's possible, stick to a 195/45 or similar.
