This is a sticky topic.
  • dmoney(AB)
    • 1372
    #5221
    I'm easy
    What's my options
    Keep in mind they are going on a 2jz swapped mtech1 for now
    mtech1/2jzgte/r154/275tire
    function>form
    • Mike30e
      • Jan 2009
      • 408
      #5222
      Looking to change wheels, currently running 16's on Bilstein HD's with H&R Sports, want to got to 15" Alpina's. What is the difference in going to a 15x6 front, 15x7 rear rather than all 15x7? Is it only cosmetic? What is the best size tire combo for this?
      • mbonanni
        • Sep 2011
        • 6236
        #5223
        17x7.5
        et0
        205/40
        Fit?
        • LJ851
          • 7918
          #5224
          ^225/50/16 WAY too tall, 225/45/16 is what you want.
          Lorin
          The M30 is God's engine.
          • aDdiktD
            • Nov 2011
            • 32
            #5225
            Quick question. 15x8.5 +20 and 15x9 +10 steelies ont my e30. On bilstein/ground control. What tire size should I buy? thx!
            • FunfGan
              • Jan 2011
              • 4958
              #5226
              Best offset for 15x8, 235/50? The wheels are +38, but I could get spacers up to 20mm.
              Thanks in advance!
              Go here be happy!
              Ratchet Garage e30 V8 build.
              • Hans Gruber
                • 157
                #5227
                Originally posted by Hans Gruber
                Buying some e60 style 134's for my 91. Running 5 lug adapters as well. Need a idea on adapter sizes with a 16x7 et20 wheel. 15f/20r mm adapters sound about right? I'm on kw v1's trying to get it as flush as possible
                Originally posted by Mystikal
                Smallest adapters are 18-20mm. I'd suggest staying as thin as possible.
                Awesome thanks. I guess a 205/50 would be ideal but a 195/50 would keep me from scrubbing at et0?
                My Pleasure:02 Honda 954, 02 Fronty 4x4
                My Pain:91 BMW E30, 90 S13(sr'd)
                "granthr said: ↑
                I mention Metric Mechanic because it is a great way to empty your wallet to get unverified horsepower gains."
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  #5228
                  Originally posted by dmoney(AB)
                  I'm easy
                  What's my options
                  F: 20mm spacer 215/40
                  R: 15mm spacer 235/40
                  Rolled rear arches
                  • Mystikal
                    • 9602
                    #5229
                    I wouldn't go with 15x6 fronts. 15x7 all around minimum, and 205/55 or 225/50 tires.
                    • Mystikal
                      • 9602
                      #5230
                      Originally posted by mbonanni
                      17x7.5
                      et0
                      205/40
                      Fit?
                      Yes, with rolled everything.
                      • Mystikal
                        • 9602
                        #5231
                        Fronts might need a 3-5mm spacer depending on perch height and tire width to clear the coils.
                        205/50 all around is probably best.
                        • Mystikal
                          • 9602
                          #5232
                          Thanks in advance!
                          That's a tough one. I'd actually suggest mounting them and seeing how much clearance you need to create either with trailing arm grinding or via spacers (probably like 5mm). Not much additional space is needed and you don't want to overuse spacers and end up rubbing on the fender.
                          • Mystikal
                            • 9602
                            #5233
                            195/50 will still rub. 195/45 would be better.
                            • FunfGan
                              • Jan 2011
                              • 4958
                              #5234
                              Thanks! My thoughts exactly on spacers, I wanted to use as small as one to get by. And by trailing arm grinding, do you mean the pinch weld that sticks out a bit?
                              Go here be happy!
                              • wildstoats
                                • Sep 2007
                                • 896
                                #5235
                                Ok, after much waffling I finally obtained a set of wheels that I'm going to try out and I need some advice on spacers.
                                16x7 - Offset: +30
                                Late body style car, lowered on Ground Controls, camber plates, etc. I'm going to be running a 205/50 Star Spec. Looking for the most aggressive fitment I can pull off with rolling only. Thanks again, hopefully now you won't hear from me for a while.
