Originally posted by rnw
View Post
This is a sticky topic.
Originally posted by StreetMafia21 View Postsup, ok so i just picked up some 16x9 et12 im having them re-drilled to 4x100 .what tire profile will i need. For a nice stretch?? will i need spacers to fit the fronts ??will rolling fenders flat be ok or will I need to flare the fenders out as well??
Originally posted by GunMetalGrey View Post16x9
Et25
DTM flares, which adds two inches out on the flares.
Coilovers
I want the tires to be filling out the flares, but not have to worry about rub, I can run spacers no problem.
Same size tires all around.
From what it sounds 245/45 with 15mm spacers all around?
Could I get away with a 245/50? In order to get road tires lol
Originally posted by Pl3wA View Postsorry, offset is +32. pretty ridiculous. will it be even possible to use the fronts? 9.5"? if so, will 18mm spacers work and which tire size?
Thank you
Originally posted by dmoney(AB) View Post17x8 et 32
17x8.5 et 32
215/40
What spacers would you use
Possible to fit a wider tire?
10mm front spacer, none in the rear. 235/40 all around. The rear will be very close to the trailing arm seam and may need either a tiny spacer or a slight grinding of said seam.
mystikal, here to badger you again
I decided to go ahead and add flares (IE or dtmfiber) to my project car so I can fit some better sized rubber on my wheels, which are the typical brock b1 17s, 8.5et13 fronts and 10et20 rears. What can I fit now? Don't mind spacers if need be. I was going to go with newmans set up of having 245/45 and 275/40 as he had IE flares also. Any other thoughts?
TIA2008 335i - n54b30
1991 318i - m52b28
1994 fzj80 - LAND CRUSHER
TIA
