This is a sticky topic.
  • BMWe30Mstyle
    • Jan 2009
    • 28
    #5461
    I want some 225s for my stock riding 88 325ix, is this an option? Any recommendations for a good all season tire?
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #5462
      Really aren't many choices in 225 that are all-season and fit an E30...Falken ZE-912 in 225/50/15 is the only one I can think of. It's a great tire but not that capable in the snow/ice. Not recommended for anything but very light winters. They should work without spacers on stock iX weaves as far as I know.
      • andrewm
        • 456
        #5463
        So, I have a set of rims I'd like to try out - however...
        they are 15x7 ET 35, and they fit a honda...
        my memory suggests that I will need a hubcentric ring and probably a spacer (I'm not an IX). Anyone know what exactly I'd need to make it look proper and fit proper?
        1987 Delphin 325e Sedan - Natalie
        1990 325i 24v
        1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
        • lambo
          Captain Scene Points
          • 10953
          #5464
          Well, euroweaves are 15x7 et24, so a 10mm spacer would get it at stock fitment.
          • andrewm
            • 456
            #5465
            Ah - good point. I never thought about that. I don't really "do" rims usually...I take it I would need longer bolts and the hubcentric ring?
            1990 325i 24v
            • Mystikal
              • 9602
              #5466
              Hubcentric rings and 15mm spacers all around.
              • andrewm
                • 456
                #5467
                Thanks - I think I figured it all out. I cant find any metal huncentric rings, is fairly common that they are plastic? Im looking at the honda hub, to the e30 hub which is 56.1 to 57.1
                1990 325i 24v
                • Mystikal
                  • 9602
                  #5468
                  Chances are the wheels have a much larger bore (75mm or similar) rather than being hubcentric to the Honda. If they are indeed Honda-bored wheels you can't use them without either custom adapters or machining the centerbore. Plastic rings are fine for street use.
                  • andrewm
                    • 456
                    #5469
                    http://www.justforwheels.com/index.j...cat=hubcentric shows a 56.1 ID to 571 OD ring, is that not correct? Thanks for the tip, I will measure the rims tonight or this weekend.
                    1990 325i 24v
                    • Mystikal
                      • 9602
                      #5470
                      No, think about it. Your hub is 57mm, and the wheel's hub is possibly (but not likely) 56.1mm. You need the scientific opposite of rings, which is removing material inside the wheel so that it can go over your hub.
                      But, again, unless they're OEM Honda wheels there is a very little chance they are actually 56.1mm.
                      • andrewm
                        • 456
                        #5471
                        Oh, interesting. I got them backwards, I thought BMW was the 56.1. Well crud...thanks ha
                        1990 325i 24v
                        • jackbenny
                          • 414
                          #5472
                          Pipe dream hypothetical:
                          16x8.5 et15 front and rear
                          Is 225 wide a possibility or should I end my mental exercise?
                          Car lowered on ground controls with rear fenders rolled.
                          -Josh
                          Check out my build thread...
                          http://www.r3vlimited.com/board/showthread.php?t=131055
                          Need parts? Support the community!
                          http://www.gutenparts.com
                          http://www.blunttech.com
                          • MR E30 325is
                            • Dec 2008
                            • 3300
                            #5473
                            Its finally time for a new wheel size and setup for the E30.
                            Mystikal, I need some help.
                            91 318is, 5 lug, coilovered on E38 style 5's.
                            I will be rolling, and potentially flaring the fenders a bit.
                            Are 225/45's doable? How about 235/45's?
                            The more rubber the better, as the car has the potential to have the S52 resupercharged in the near future.
                            Thanks!
                            My previous build (currently E30-less)
                            http://www.r3vlimited.com/board/showthread.php?t=170390
                            A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                            • BMWe30Mstyle
                              • Jan 2009
                              • 28
                              #5474
                              thanks mystik
                              i have snowmoblie treads but the wide stanse my short spring white one has is so beautiful i need them for summer.. perhaps im over my head and should stick with 205 but there are no options in 215 all season either.. no big deal ill catch the yoko again in 205
                              • Mystikal
                                • 9602
                                #5475
                                Yeah, probably not gonna happen. I can see a 215/45 working though. And the sticky Kumho XS comes in that size (there's nothing in 225 that can touch that tire).
