who is running 245's (16's) ? Post a shot from the rear if you are. I'm looking at a wide "stance" for the rear say .. 245 (45/40) 16 in the back and 225/45/16 up front... just what to know who is running 245's.. cheers big ears
	This is a sticky topic.
 Hi e30 noober here, sorry if anyone askEd already. I am looking into some wheels FS the specs are 16x9.5, et 32 all around, with a lug pattern of 5 x 120 can I make these fit my e30 with BC coil overs? If so what size/brand adapters should I use? Also tire size reccomendation.
 Thanks in advance
 -AdamComment
 So I have stock (at the moment) suspension on my 89 i. I am trying to run a redrilled set of style 4's (16x8, et23) with 205/45's. The fronts are currently not clearing the caliper bracket. What size spacer should I run up front? and should I run a spacer in the back to keep it from looking funny?Comment
 Alright
 Looking to fit a 245/35 in the rear and a 215/40 in front
 Fenders rolled.
 Here's my options:
 Front and rear:
 17x9 et20
 Fronts
 17x8.5 et 20
 Rears
 17x10 et15
 Fronts
 17x9 et35
 Rear
 17x10 et20
 mtech1/2jzgte/r154/275tire
 function>formComment
 25mm adapters, massively stretched tires (205/45 or 215/40), and likely a fender pull in the back.Hi e30 noober here, sorry if anyone askEd already. I am looking into some wheels FS the specs are 16x9.5, et 32 all around, with a lug pattern of 5 x 120 can I make these fit my e30 with BC coil overs? If so what size/brand adapters should I use? Also tire size reccomendation.
 Thanks in advance
 -AdamComment
 Depends on your brake pads. You will have to experiment a bit, most get away with 5mm fronts with style 4s and 5s. I'd go 10mm in the back for balance.So I have stock (at the moment) suspension on my 89 i. I am trying to run a redrilled set of style 4's (16x8, et23) with 205/45's. The fronts are currently not clearing the caliper bracket. What size spacer should I run up front? and should I run a spacer in the back to keep it from looking funny?Comment
 None of the rears will fit very easily. Expect to be working the fenders heavily and you better have high rear spring rates also (650+). The only fronts that fit without spacers are the 17x8.5s. But those come with the least likely to work rears. I'd go with the last set, with a 20mm front spacer.Comment
 want to run BBS rs025 16x8 et36 will work with h&r race and Bilstein Sport - fronts e90 hats?
 I know I need to run the adapters, witch ones and what tire size you recommend?If you want to feel rich, just count all the things you have that money can't buy.Comment
