This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #5581
    Originally posted by goldtl
    The wheels are BBS RS 16x8.5 +18 and 16x9 +12.5. What tire size do you recommend for a s52 swapped convertible e30 with rolled fenders?
    205/45 and 215/45, respectively.
    • Roysneon
      • 4505
      #5582
      How about M-SystemII's on a late model car with E30M3 suspension? Want as little stretch as possible.
      Wheel specs:
      17x8 et20 front
      17x9 et22 rear
      Originally posted by mbonanni
      I am a pursit now.
      • alpineII_dirty
        • Apr 2012
        • 186
        #5583
        Okay so im coming on 15x8, i would like a decent poke so any problem with 0 offset or if not +20? Running on Vogtland springs and as well getting e90 drop hats, so what tires can i run to clean up the gap as much as possible..215/50 rear? 205/50 front????
        • dhcg86
          • Mar 2012
          • 300
          #5584
          How do I make style 42s from an e39 with 235/45/17 fit on my 86 325e ?
          5x120 bolt pattern. 17x8 et 20
          I either drill and fill or swap in 5lug right? But once I do that, how do I get the wheels to fit? Gotta have big tires for my planned 400hp
          and if I dont do the 5 lug, whats the best tire size for 400hp? Im worried about not being able to put all that power to proper use
          • cardnation
            • May 2012
            • 123
            #5585
            235/45 might as well be monster truck tires on these little old E30's.
            I rolled one of my A4 wheels (same specs as above) up against my vert, and I couldn't even lower the jack down.
            • dhcg86
              • Mar 2012
              • 300
              #5586
              sigh, all the more reason to get a good 16" wheel with some wide sticky tires
              • asuj158
                • Nov 2008
                • 1206
                #5587
                the 17x7.5 are +45 how would those fit? im eventually going to roll the fenders if that helps
                • dhcg86
                  • Mar 2012
                  • 300
                  #5588
                  17.5J x16 ET 35, borbet type Cs.
                  they also appear to have some flat spots in 2 of the tyres.
                  Can I use these on my e30 without spacers? Will spacers allow me to run wider tires in the rear?
                  Should I worry about the flat spots?
                  Sorry for all the questions; Im a noob!
                  • Mystikal
                    • 9602
                    #5589
                    Wheel specs:
                    17x8 et20 front
                    17x9 et22 rear
                    215/40 F 245/35 R is ideal. Requires a flat rear roll and linear, high spring rates. Otherwise 215/40 all around.
                    • Mystikal
                      • 9602
                      #5590
                      There's guys running the +0 15x8s but I think they look terrible without lots of front camber. I'd suggest +20 with 10mm rear spacers. 205/50 all round.
                      • Mystikal
                        • 9602
                        #5591
                        Tires are useless. I wouldn't trust redrilled wheels with that much power, and with adapters you can't fit wide tires.
                        • Mystikal
                          • 9602
                          #5592
                          Needs massive spacers, 25mm all around minimum to look decent.
                          • Mystikal
                            • 9602
                            #5593
                            They need spacers. 15mm all around is ideal. 225/45 can fit all around. Try rolling on them to see how bad the flat spots vibrate (put them on the rear).
                            • ACHTUNG
                              • May 2005
                              • 2397
                              #5594
                              I don't know why my brain can't figure this out but here's a 3-piece wheel scenario for you to help me calculate:
                              The 3-piece wheels are 16 X 7.5 et 23 with 1" lips. What would be the new wheel offset if I added 2" lips?
                              Using an online split rim offset calculator I came up with the new wheel width as 8.5" and the offset would be et 10.3. Did I calculate this correctly? If so, how would this new width and offset fit on a late model 325i?
                              1989 US E30 Cammed S52
                              Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                              • cardnation
                                • May 2012
                                • 123
                                #5595
                                1 inch = 25.4 mm
                                So 23-25.4= -2.4mm
                                I've had a long day so check my math. :yawn:
