This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #5566
    Originally posted by dantes
    want to run BBS rs025 16x8 et36 will work with h&r race and Bilstein Sport - fronts e90 hats?
    I know I need to run the adapters, witch ones and what tire size you recommend?
    20mm adapters all around, 205/45 tires. This won't need fender rolling.
    20mm F / 25mm R adapters, 205/45 tires. Will need a rear roll, will look dope.
    • cardnation
      • May 2012
      • 123
      #5567
      I picked up these BBS RX's for a steal of a price. :-D
      Will they fit properly with an 18mm adapter and 215/40/17?
      Specs:
      5X112
      17x8
      ET35
      • Vivek
        attention whore/retard/bitch
        • 6167
        #5568
        With an aggressive roll/pull, could I run at 235/50/17? I'm looking into some style 19's with them (I'll use custom adapters) and I'm not sure how bad it would be to run a tire 2.3" oversized.
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
        • Mystikal
          • 9602
          #5569
          Specs:
          5X112
          17x8
          ET35
          Yup! Perfect fitment.
          • Mystikal
            • 9602
            #5570
            Not even close, you're looking at a 195/45 or 205/40.
            • CrusherCurtis
              • 2532
              #5571
              Sorry if this has been beat to death, I have 18" staggered style 5's. The offset on the 18's is the same as the 17x8 5's which is et 20. Whats the smallest size spacer I could get away with and clear the front calipers? They've been filled and drilled, I really don't want to go bigger than 5mm.
              • lambo
                Captain Scene Points
                • 10953
                #5572
                Originally posted by CrusherCurtis
                Sorry if this has been beat to death, I have staggered style 5's. The offset on the 18's is the same as the 17x8 5's which is et 20. Whats the smallest size spacer I could get away with and clear the front calipers? They've been filled and drilled, I really don't want to go bigger than .
                What you could do to double check is cut up some cardboard and do test fits.
                • CrusherCurtis
                  • 2532
                  #5573
                  Yeah, but I know somebody has 17x8 et20 style 5's and know's what spacer is needed. I'm finding answers through searching only for the e38 16" style 5's
                  • cardnation
                    • May 2012
                    • 123
                    #5574
                    Calipers can vary from car to car, whether that be due to non-oem replacements or pad wear...etc. Because of this I tend to like testing myself, especially on these old cars.
                    What I've done in the past, is buy a couple bags of 1mm washers. Stack a few together and tape them up. Mock the wheels up and see how they fit. Guaranteed perfect fit every time.
                    Total investment about $2.50
                    • lambo
                      • 10953
                      #5575
                      What I've done in the past, is buy a couple bags of washers. Stack a few together and tape them up. Mock the wheels up and see how they fit. Guaranteed perfect fit every time.
                      That's not a bad idea. I'm gonna have to steal that...
                      • CrusherCurtis
                        • 2532
                        #5576
                        Where do you get your 1mm washers from? I just came back from home depot all I could find was 2mm
                        • cardnation
                          • May 2012
                          • 123
                          #5577
                          We have a nuts and bolts hardware (not Lowes hardware) store here that sells just about everything, hardware/fastener wise.
                          With that said, 2mm would get the job done as well, since these are only for judgment/guestimation.
                          • asuj158
                            • Nov 2008
                            • 1206
                            #5578
                            widest tire i can fit on a 17x7.5?
                            • goldtl
                              • Oct 2009
                              • 19
                              #5579
                              The wheels are BBS RS 16x8.5 +18 and 16x9 +12.5. What tire size do you recommend for a s52 swapped convertible e30 with rolled fenders?
                              • Mystikal
                                • 9602
                                #5580
                                235/40 is about the most you'll want on there. Offset has to be dead-on for it to work (+22 to +27 should do it).
