This is a sticky topic.
is there any benefit to running spacers? any downside?
the wheels were 250 so an easy sell. I dont want to spend 500 on tires only to find its not optimal fitmentComment
17x8.5 Et-7 on E34. Thoughts?1991 e30 328i M52 swapped: Gone
1995 e34 540i/6 1 of 76 Clean
1985 e28 euro 525i the dailyComment
What is the drawback to running 15x6 in the front?Quote:
Originally Posted by Mike30e
Looking to change wheels, currently running 16's on Bilstein HD's with H&R Sports, want to got to 15" Alpina's. What is the difference in going to a 15x6 front, 15x7 rear rather than all 15x7? Is it only cosmetic? What is the best size tire combo for this?
I wouldn't go with 15x6 fronts. 15x7 all around minimum, and 205/55 or 225/50 tires.Comment
Just picked up some wheels, Gonna slam, camber etc. I plan on tucking tire in the rear a little. any advice on tire sizes??
BBS RS
16X8.5 +10
16X9.5 +15
I was thinking
205/45/16
215/45/16
any thoughts?Comment
17.5J x16 ET 35, borbet type Cs.
Can I do any wider of a tire with 20mm spacers?
Should I just get a wider wheel set? Or even a staggered set?Comment
What are tire size options for Bcaps other than 195/65/14? Could 215/60/14 be the only possibility?
meaning the circumference will be very close, with a wider tread.Last edited by cabriodster87; 07-16-2012, 04:31 AM.sigpic
Reich und Roll!Comment
Looking at Borbet Type A wheels
16x7.5 et +20 all around for now, unsure of 16x9 offsets
Car rides on German Engineering Coilovers, Bilstien Sport Struts
Going for a flush look. Recommend spacers or good as is? Also, unsure of the appropriate tire size. Was thinking a 195-45-16 or 195-40-16.
Also, cannot roll fenders. Super rusty northern car with horribly rusty fender.
Thanks,
NickLast edited by Nick's e30; 07-16-2012, 06:18 AM.Comment
16x8.5 +10. Excellent fitment.I don't know why my brain can't figure this out but here's a 3-piece wheel scenario for you to help me calculate:
The 3-piece wheels are 16 X 7.5 et 23 with 1" lips. What would be the new wheel offset if I added 2" lips?
Using an online split rim offset calculator I came up with the new wheel width as 8.5" and the offset would be et 10.3. Did I calculate this correctly? If so, how would this new width and offset fit on a late model 325i?Comment
205/55 is too tall. 205/50 is what you want. You would barely see a stretch, if at all.Originally posted by DoctorLondomGot an '89 325i on stock suspension. Looking to get the ESM-002R 16x8 ET20 all around with 205/55/16 tires.
I'm assuming this setup will bolt on and work fine?
Will I be able to fit H&R/Bilstein Sports without rolling the fenders with this setup?
Would the 205 on the 8" wheel look too ridiculous? Seems like a moderate stretch.
I decided against the 15x8" ET15 as it seems a bit aggressive and would require rolling for a moderate drop even with 205s. Am I correct in my thinking?
Thanks!
The 15" setup is definitely more aggressive and would require a roll.Comment
DREWLIENTE
