This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #5761
    Originally posted by Nick's e30
    16x9 on all 4 corners, et15, will I need any kind of spacer or fender rolling? Ultimately going for a flush look.
    Thank you!
    With 90% of suspension setups you will need a 3-5mm front spacer to clear the strut body. If you use a 205/45 tire you may get away with not rolling the rear fenders but it will depend on ride height and spring rates.
    • Mystikal
      • 9602
      #5762
      Originally posted by ThatOneGuy97
      alright i looked all over online and well there arent much answers for ix questions so here i am again. what offset will i have to run with a 8 inch wide rim on an ix or do i have to run 7.
      +30. An iX can fit everything a standard E30 can (more if you modify the metal fenders underneath the flares). You just need a slightly higher (by 8-10mm) offset.
      • ThatOneGuy97
        • Aug 2012
        • 100
        #5763
        Thanks thats a big help!!! i guess i just had a misunderstanding the first time
        SELL ME YOUR E30
        1988 Apline 325iX SOLD
        1999 MINT Lincoln Towncar Pimpin
        My Bike when they shit out :wgaf:
        • asuj158
          • Nov 2008
          • 1206
          #5764
          would 17x9 et20 fit? much rolling required. 255/45 rubber
          • Mystikal
            • 9602
            #5765
            Front or rear? Either way the tires are 2" too tall.
            • asuj158
              • Nov 2008
              • 1206
              #5766
              that rubber would be in the rear, 17x9 all the way around. I have 205/45/17 on tha back right now and they fit with a bunch of space, but thats 205...
              • masduro
                • Aug 2011
                • 221
                #5767
                I just got a set of mercedes wheels 16x8 et34 and I'm going to order custom adapters. My question is what thickness? I'm currently running 16x9 et15 and want the same fitment. Also plan to run 205/40's
                Thanks
                • 320icar
                  • Aug 2012
                  • 25
                  #5768
                  I would think a 235/45 or better yet a 245/40 would fit much nicer
                  • johnjohnsons54
                    • Mar 2012
                    • 228
                    #5769
                    Due to my new coilovers, I'm looking to run a pair of good performance oriented 205/45/16's on 16x8's in the front of my car.
                    Any suggestions for some 205/45's that are less prone to looking super stretched and are a good mix of performance vs value?
                    ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
                    In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
                    I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!
                    • ColdAccord
                      • 5926
                      #5770
                      I have 4 17x8.5" m contours for my e36 m3 right now. According to wiki, m coupe/roadster rear wheels are 9" wide. I don't mind rolling my quarters, but how wide of tire can I fit in back? Any pics or precedent?
                      Thinking of picking up a set of m contour rears from an m roadster/coupe for my rears
                      Originally posted by blunt
                      • badnerd
                        • May 2008
                        • 65
                        #5771
                        Hey sirs...from Jamaica.
                        16 x 8's all around +20, lowered on IE stage 3 springs. i got 15mm spacers for the rear (not sure if these are necessary, willing to ditch)
                        wt tires do you recommend, looking for a meaty rear tire.. and something decent for the front to clear the strut tower. 87, 325e. dont intend on rolling
                        appreciate it, thanks.
                        • randomsv650
                          • Jul 2011
                          • 614
                          #5772
                          BBS RS189. Rims measure 15x7.5" and 15x8.5" with ET38. The widths seem odd to me, but whatever i guess. My DFORCE rims measure exactly 15x7.
                          Currently there are stretched tires on the BBS rims. On the dforce, im running 205/55-15 Kumhos. I like the look of the current tires, though they probably could be a size smaller for sidewall height (maybe 45's?).
                          What should i run on the BBS? The car is sitting on JOM coil overs. Would like to avoid rolling fenders. Seems like the rear there should be plenty of clearance, front im not sure. Any tips are appreciated!
                          I am thinking of running a 225/50-15 rear and 205/50-15 front. Little lower profile series than whats on there with more width in the rear (since the rims are wider than what im running)
                          How the car sits now:
                          • hotrodlincoln
                            • 413
                            #5773
                            If I'm running 17 x 8 front and 17 x 9 rear et13 all the way around with a 10mm spacer up front to clear my airbags. What would I do with 17 x 8 et20 all the way around??
                            • tytypetersen
                              • Mar 2012
                              • 347
                              #5774
                              Hey, i got a set of bbs rs's. They are 5x114.3 and 16x7.5 with et35, but i'll be getting 18 or 20 mm adapters (putting the final offset at around et17 to et15) Wondering if they will fit without problems with some 205/45s. Question 2, the wheels right now have a .5 inch lip, and I gotta good deal for two 1.5 inch lips. This would make the rear wheels 16x8.5 but with et -8 (with adapters), how much work would it be to pull off this setup? By the way I'm on h&r cupkit, but will likely be getting some sort of coilover setup in the near future.
                              Thanks in advance, hopefully all my math is correct!
                              • Mystikal
                                • 9602
                                #5775
                                235/40 or 245/35 are about the limit. 245/40 with enough fender massaging.
