Has anyone use style 32 from e39 wheel specs front wheels are 8JX17 Offset is ET:20 & Rear Wheels are 9JX17 Offset is ET:26 on a e30 w adapters?
This is a sticky topic.
ah ok interesting. would you think those widths and offsets will work. and what tyre sizes would you think could pull it off? i want to have some decent tyre width for optimal grip.Comment
You're limited to 225/45 all around. The Hankook R-S3 comes in that size and is a fantastic tire.Comment
16x8.5 et -05 + 205/40 Front - 18mm spacers + camber plates ~3.5* camber
16x9.5 et 04 + 215/40 Rear - 15mm spacers + camber
offset is final, after spacers
thoughts? Looking for a wee bit of poke :giggle:Last edited by pandaboo911; 10-26-2012, 03:12 PM.
i have filled and drilled 17 inch style 5s. whats the smallest spacer i can use to clear the front brakes without grinding them down or anything?Comment
Would 17 x 7 ET 27 Beyern Mesh wheels work for an '86 325 on eibach springs lowered 1.6" front 1.4" rear? My goal is to avoid using spacers or rolling fenders, if possible, but I'd also like to run 17" wheels since it seems that the tire selection is better for that size (I think?)Comment
2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
what would you recrommend for 16x9 et 12 front and rear for tires? I want something pretty thick. My front and rear are on adjusters so height can change. I have 205x45 and it's not enough meat for my liking.2014 Alpine White 335i MSport
(Daily Driver)
KW V2 Coilovers
i was doing some spirited driving and my front left tire started making a faint hissing noise. So I must have broken the bead seal.2014 Alpine White 335i MSport
(Daily Driver)
KW V2 Coilovers
