This is a sticky topic.
  • esthero
    • Feb 2013
    • 6
    #6226
    Originally posted by Mystikal
    So stock E30 hubs redrilled, right? 215/40 is the widest you'll fit without fender rolling and even then it will be tight in the rear on an 88+ car.
    yup stock e30 hubs redrilled. so with 215/40 i will not need to roll the fender and able to have 4 adults right?
    time to do some tires shopping and save up some money to buy m3 suspension. :D
    thanks man, really appreciate your help
    • fporro
      • 1859
      #6227
      I'm getting a little confused, are you guys drilling rims or actual hubs ?
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #6228
        If it's an early car yes, late car no it will likely rub with rear passengers.
        • esthero
          • Feb 2013
          • 6
          #6229
          mine is the actual hubs
          • RGCintha29073
            • Dec 2009
            • 471
            #6230
            I was thinking about doing this as well...got any pics of this done with fitment? Did you make a jig to drill with or had them done?.....
            Anyway, got a set of the Rota Slipstreams 16x8 et20 and they currently have 215/40 16s on them which need to be replaced. No rubbing issues. Just not enough tire for me.
            I see you recommend the 205/50 16s but is it worth it to rent a fender roller and spend the extra money for the 225/45 16s? Would that be all that is needed to run the 225/45s? There is a significant price and selection difference between the two just by looking at Tire Rack.
            • d3r1ckr0x
              • May 2008
              • 25
              #6231
              Hmm hello, trying to fit some Varrstoen V3 16x9 et15. Tire choice is going to be 205/45 (Federals to be exact) I'm already assuming that a small spacer (5mm) would be needed for the front to clear. Fenders are already rolled. Suspension is Bavauto/BillyHD fronts and KYB rears. Someone please confirm this before I start ordering the wheels. Thank you.
              • Kcaps
                • Dec 2012
                • 45
                #6232
                4X ESM RS002 16x9 4x100 bolt pattern ET15 57.1mm hub bore
                What size tires would fit best and spacers for the front? Thanks in advance.
                • Wrinckled
                  • Dec 2012
                  • 113
                  #6233
                  Stuck in a similar situation. I've got a 8.5" in the front and ET 17, want to know what tires I need to fit.
                  • AlphaE
                    • Sep 2011
                    • 503
                    #6234
                    i got a free set of style 42's. 17X8.5 i believe. they have 235/45/17 on em. Ive read that size rubber will never work... What size rubber would i need to run them and what spec adapters? im still 4 lug... MAN i love these wheels... may have to sell though.. wish they came in like a 15..
                    Now with 2.7i power!!!
                    • Mystikal
                      • 9602
                      #6235
                      [ATTACH]66046[/ATTACH]
                      Most 225/45/16s will fit with just a basic rear fender roll. May I suggest the Dunlop ZII.
                      • Mystikal
                        • 9602
                        #6236
                        All correct.
                        • Mystikal
                          • 9602
                          #6237
                          205/45 and 5mm. 215/40 works also but leaves you with a bit less ground clearance.
                          • Mystikal
                            • 9602
                            #6238
                            Lots will fit, more depends on what you have in the rear and if you want them to match.
                            205/50, 205/45, 215/45, 225/45, etc all fit.
                            • Mystikal
                              • 9602
                              #6239
                              18mm adapters and 195/40 or 205/40 tires (rear fender roll needed).
                              • AlphaE
                                • Sep 2011
                                • 503
                                #6240
                                195 on a 8 inch rim??!! how stretched is that!!???
