	This is a sticky topic.
 I am sure this has been answered many times, but I am looking at Hoosier Autocross tires in P275/35ZR17 on a 9x17 wheel.
 I had originally thought about going with KAMOTOR flares, but he has stopped production. Now I am leaning to my old plan A. I have a set of carbon fiber e30m3 fenders ready to install.
 My concern is these wouldn't provide the needed clearance, especially on the front. The front fenders are from Compitition Concepts (no longer in production)
 any thoughts or input would be appreciated.Comment
 Perfect, thanks! That's the best bolt length to run with those spacers? I've read 40 and 45mm but I'm not sure which is best. The wheels were filled and re-drilled to 4x100 if that makes any difference.
 Thanks in advance!'16 Volkswagen Golf R | 6-speed | Oryx White Pearl | Titan Black Leather | Tech Package
 '88 BMW 325 | 5-speed | Bronzitbeige Metallic | Natur Sport Leather | M20B25 swap | 3.73 LSD - GoneComment
 What should I be looking at adapter and tire wise for 17x8 et20 M Systems. Also, what offset is most common for 17x9 M Systems? What would be ideal for those in the rear?
 Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
 Rear only? 215/45s and a very minor roll.Comment
 None. A square-shouldered tire on a 15x8 is at least a 225/50. That won't fit without rolling and a perfect offset.question is about fitment on an 87 325is
 keeping this in mind, I prefer no stretch and i like tires that look meaty. in other words the more tire the better
 for 15x8" wheels what is the perfect offset that would require no spacers and no fender rolling with what sized tire?
 Same exact question for a 16x8" wheel. offset, no spacers/rolling and what sized tire..
 I'm trying to decide between 15's or 16's considering tire pricing/size, available offset etcComment
 Like 195/40. That's an overtly aggressive setup.Comment
 Yup, 205/50s will work. Ask ESM if the wheels requires tuner bolts.Hey guys so im looking to install a set of ESM 002r 15x8 et15 rims all around on my 325i 4 door on GC coils. After a ton of reading just wanted to ask if i installed 205/50/r15 tires all around if i should expect rubbing issues? Also can i use stock wheel bolts for these rims or do i need some aftermarket wheel bolts?
 Thanks in advance.Comment
 195/40s are pretty much required for that fitment. Very aggressive.Hey everyone, massive tire fitment noob here. I just picked up a set of 17in style 5's with 235/45/17 tires for a steal. I know the tires won't fit my E30 (1991 318i, stock suspension, pretty much all stock). I am planning on getting some GE coilovers once they get in stock but for now it's at stock height. I was thinking of running some 42 draft design 18mm adapters all around. Would 215/40/17 tires work for this?
 Thanks!Comment
 Sick wheels.where can i get some 20 mm spacers that will mate a mini cooper wheel to my e30? looking into purchasing 17x7.5 et 48 ac schnitzers and I think the centerbore is 1mm less than the e30.
 I have a quote from a machine shop for 35$ a wheel to bore it out to fit the e30 but then i would have to buy 20 mm spacers anyway because of the offset so I'm hoping to kill two birds with one stone and save some mula.
 I'd personally buy an off the shelf set of bolt-on hub extender spacers made for E30s in 25-30mm and give them to a local machine shop. Removing 1mm from each spacer should only cost you $50-100 total.Comment
 I've only ever run 14's so even though I'm not new to low e30's, I kind of am new to getting over sized wheels to fit.
