	This is a sticky topic.
 Really not sure. Sorry!I am sure this has been answered many times, but I am looking at Hoosier Autocross tires in P275/35ZR17 on a 9x17 wheel.
 I had originally thought about going with KAMOTOR flares, but he has stopped production. Now I am leaning to my old plan A. I have a set of carbon fiber e30m3 fenders ready to install.
 My concern is these wouldn't provide the needed clearance, especially on the front. The front fenders are from Compitition Concepts (no longer in production)
 any thoughts or input would be appreciated.Comment
 Either one can be ideal depending on the thickness of the wheel hub. If you're ordering online I'd suggest going with the 45mm. Worst case you can grind 1 mm or 2 off the bolts if they're too long (not likely).Comment
 Not a fan of adapting 5 series wheels because of the resultant 0 offset setup. That said, they can work with camber and tiny tires (195/40 ideally).
 Rear M Systems not from an E31 are all in the mid 20s.Comment
 Wow, I didn't expect that. You usually have all the answers or atleast most of the answers.
 How about this, off set suggestion for 17x9 wheels for a 5 lug conversion using e30 rears and Ground Control coil over e36 hybrid fronts.
 I guess trying to shoehorn a 275 under the front fenders of an e30m3 was just wishful thinking. what are your thoughts on a 245 or 255?
 thanks againComment
 That's what I was kind of expecting... looks like it's time to find some 5 lug...
 Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
 +35 front +25 rear.Wow, I didn't expect that. You usually have all the answers or atleast most of the answers.
 thanks again
 245/40s are about the edge of fitment due to overall diameter. 255s are all too tall.Comment
 16x8 et0 wheels front and rear.
 i'm on coilovers so height adjustment is not a problem..
 i was just wondering if you had any suggestions for a flush meaty fitment(?).
 Square shoulders if possible or maybe a little stretch.
 I'm currenty on rubber bands. 205/40/16. (Too low and thin. lol)
 If i raise the car it'll look dumb so i figured i might as well get better tires and fitment.sigpicComment
