This is a sticky topic.
  • yahh
    • Aug 2012
    • 800
    #6796
    I know they make fallen ziex I think in that size
    Sent from my GT-N7105 using Tapatalk 4
    s50 86 325e Project
    S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
    Feedback Thread
    • NATOBOT
      • Jun 2012
      • 94
      #6797
      ASK ALL WHEEL/TIRE FITMENT QUESTIONS HERE - The Official Wheel/Tire Fitment T...
      Hey how's it going I was wondering what you recommend for my 91 325i it's on ground controls with shortened struts. The rims I got are. 16x 8 ET 25 all around. The front rubs the caliper slightly. What do you suggest? And I got 205/40/16 tires
      • Bimmerthusiast
        • Aug 2013
        • 146
        #6798
        225/50 on a 16x8. Will that have fender issues even at a slight drop? I will have coilovers with it so height can be adjusted. I just want to know if 225s are way too wide for the e30. Thanks!
        • LJ851
          • 7918
          #6799
          ^ you're going to need to post the offset of the wheels to get a clear answer.
          225's are not too wide with the right offset.
          Lorin
          The M30 is God's engine.
          • Bimmerthusiast
            • Aug 2013
            • 146
            #6800
            Does anyone have pics of 205/55 on 16x8 +25?
            I'm getting 16x8+25 and I know all you guys say 225/45 is ideal for this but the only cheap 225/45/R16 tire on tirerack are the ZII for $512.
            Whereas the 205/55 V12 evo k110s are $368.
            Looking for a normal daily/slightly agressive setup. No massive stretch and no huge 4x4 thick setup. Will the 205/55 look okay? Thanks!
            • Mystikal
              Wheel Fitment Expert
              • 9602
              #6801
              Originally posted by achtunge30
              Hey Mystikal,
              Spoke too soon I think. Now that I am searching for 205/45 for front use I can't seem to find a matching tire to my existing 215/45 rear Kumho Ecsta XS. It seems like I may either have to go mismatched tires (read tons of Don't do it as it will result in bad handling characteristics-opinions) so I'm hesitant. The car is a vert so it does not see track duty but I do drive spiritedly on mountain drives and I do drive the car pretty frequently save for winter.
              With this in mind, do you recommend I go mismatch or not and if so what tire would you suggest in 205/45?
              Thanks again!
              Mismatch.
              • Mystikal
                • 9602
                #6802
                Originally posted by justin_l_
                Will be using z3m axles. Suggestions on something that will work without spacers? Going on superchargerd s52 e30 so traction is important.
                Not sure. Z3M axles aren't a common mod and I have no data on exact numbers.
                • Mystikal
                  • 9602
                  #6803
                  Originally posted by InNeedOfBoost
                  Running 16x8's 0 offset all around...love the way they sit, but I'm not a fan of stretching tires. I want a little bit of a meaty tire. I have Falken Ziex 612's on the rear in a 225/50 and its a little too much meat in the back. Having trouble finding some 45 sidewalls that aren't R comps.
                  Ideas, opinions
                  Buy wheels that fit E30s. 16x8 +0s don't, IMO.
                  • Mystikal
                    • 9602
                    #6804
                    Originally posted by Jozi
                    Will a 225/45 fit on a 16x9.5 ET5 work? I've got the lips on the inside of my arches flattend to the back of the arch lip and the bumps are also flattened.
                    Also, not keen on stretching tires to much and like a bit of meat in them.
                    Alternatively, how about 16x9 et9 with a 225/45?
                    Nope and nope.
                    • Mystikal
                      • 9602
                      #6805
                      Spacers to clear the calipers and any of the following sizes 205/45 205/50 215/45 225/45.
                      • Mystikal
                        • 9602
                        #6806
                        Won't work.
                        • Mystikal
                          • 9602
                          #6807
                          No. 205/55 is an inch too tall for an E30.
                          • NATOBOT
                            • Jun 2012
                            • 94
                            #6808
                            Thank you so much.
                            • InNeedOfBoost
                              • Aug 2012
                              • 512
                              #6809
                              They do when you have fender flares....
                              1991 318is - Daily/weekend track car.
                              An on-ramp is a terrible thing to waste...
                              • raleigh29
                                • Apr 2009
                                • 93
                                #6810
                                What is a good tire size for
                                16X8 20MM offset 4X100 57.2 CB (ESM 002R)
                                Car is not dropped any. Just need a good long lasting preferably meaty tire
                                Thoughts?
                                03 M3 Vert
                                89 325i
