	This is a sticky topic.
 Not enough load rating, too much fender gap, too little ground clearance. Of course all of that is in tiny amounts but it matters.Comment
 Hey there,
 I have a 86 32es diving board e30
 Have a set of bbs style 5 17x8 et20 rims off of a e39.
 What size adapters would you recommend to get with these? Or with this offset should I try to redrill them to 4x100. Also, what wheel sizes would you recommend running with these with some fender rolling, but no pulling. Just looking for a flush or close to flush look. Don't want poke though
 Thanks for the help!
 86' silver arctic metallic es
 Hi mystikal,
 Yes you're right, i can't use more wider tire than 215 in 45 profile.
 I try the 225/45 and the tire has always rubbed, even when i roll the fender still rub.. now i use 215/45 in the rear - not rubbed at all.
 But i still want wider size than 215 on the rear.. Any suggestions? (rims 17x9.5 et.26 - e36 323)Comment
 18mm adapters, 205/40 tires, fender roll.Hey there,
 Or redrill, 215/40 tires, no roll.Comment
 Yes, 235/40. The shorter diameter will ease fitment, it's a perfect E36 size.Hi mystikal,
 1989 325IX
 Ok, just wanted to make sure these would work. Thanks in advance! Do I require any spacers? I thought I wanted to be around 35 offset.
 Wheel - 16x7
 Offset - et37
 Tire - 205/45/16
 Thanks,
 DaveComment
 Just picked up some Borbet Type A's 16x9 all around. Front wheels rub slightly on the stock front calipers. How many mm spacer will I need? I've read 3mm, but is that enough? I would get 8mm, but I don't want to buy extended lug bolts too. Someone with these wheels please chime in. ThanksComment
