	This is a sticky topic.
 You need rings. Worst possible case, layers of electrical tape stacked until the wheel is SNUG (this is ghetto, but works in a pinch).I am looking at a set of wheels that are 17x7.5 et 20
 however I believe they are for a nissan cause the center bore is 59mm.
 Wheels are ATS Comp Lites.
 Questions:
 1. Can I get away with not running any sort of hubcentric spacer. The car has studs if that makes a difference.
 2. Does anyone make a 59 to 57mm adapter?
 3. My car is on Konis and GC coils. 550f/750r. I plan on using my current 16s for track wheels. What tire size for the 17s would be good for the street. I would prefer to run a 225/45 but I am not sure how that would fit. Tires are probably federal s595s as I have good experiance with them.
 Thoughts?
 215/40 is the size.Comment
 sup i have a 1991 e30 vert.
 got some bmw style 5, bbs rc090 17x8 et20 all around. i'm also running the 4-5lug conversion spacer/adapter kit which i believe is a 20mm (correct me if i'm wrong). it's the one rob sells on the forum. i am planning on buying a set of the coilovers from groupbuy #3 on the forums as well.
 q's:
 1-what tires size should i run with this setup?... i'm sure it's a pretty common one, excuse me if it's been covered over & over. this thread is getting pretty loooonnng.
 2-if stretch is needed, what brand/model tire do you guys recommend is the best?
 thanks for your wisdom!
 markComment
 Hey Mystikal,
 I've got
 1990 325i (4 door 5 speed) if it matters
 15x7 et28 RacingDynamics wheels
 205/55-15 Yokohoma S-Drives
 H&R sport springs
 Billy sport shocks/struts
 I want to swap to a set of IE3 springs with no front pads, and install an e36 steering rack. What size spacers should I order to assure I wont have any full lock rubbing issues while still getting a bit more of a flush fitment?1990 332i, 4 door
 2008 KTM 990 Superduke
 2018 Golf R, 6spd manual (Pending delivery)
 2017 Mazda CX-5 GT
 2007 Z4M Coupe - Sold to very nice peopleComment
 What is the max width tire that can fit on a 7 inch wide rim? My 205/50/15 tire ripped during the install. A local shop on my 15x7 rim'01 e46 330ci blk/blk (GF stole from me)
 '90 e30 325i Traded
 '95 e34 540i/manual swap (electric fire)
 '96 miata M-edition (not quite an e30 so i got below car)
 '93 Audi Urs-4 (like the e34 but still not an e30)
 :hitler:Comment
 sup, ok so i just picked up some 16x9 et12 im having them re-drilled to 4x100 .what tire profile will i need. For a nice stretch?? will i need spacers to fit the fronts ??will rolling fenders flat be ok or will I need to flare the fenders out as well??Last edited by StreetMafia21; 05-11-2012, 08:53 PM.Comment
 16x9
 Et25
 DTM flares, which adds two inches out on the flares.
 Coilovers
 I want the tires to be filling out the flares, but not have to worry about rub, I can run spacers no problem.
 Same size tires all around.
 From what it sounds 245/45 with 15mm spacers all around?
 Could I get away with a 245/50? In order to get road tires lolLast edited by GunMetalGrey; 05-13-2012, 09:20 AM.Comment
 195/40 or 205/40. Any model tire should do that minor stretch. Rear fender roll required.sup i have a 1991 e30 vert.
 q's:
 markComment
 No idea on how the steering rack affects clearance. 15mm all around is possible but only with a rear fender roll.Hey Mystikal,
 I've got
 H&R sport springs
 I want to swap to a set of IE3 springs with no front pads, and install an e36 steering rack. What size spacers should I order to assure I wont have any full lock rubbing issues while still getting a bit more of a flush fitment?Comment
