This is a sticky topic.
Tried to follow this and I'm lost. Sorry.Thanks jay, i think i will try the 225/40 and 245/35.
Can i ask for Another question ?
I have oz mito type ii parts :
- 4 pcs oz mito ii center (spec on the wheels 19x8.5 et.13)
- 2 pcs 18x1.5in lip
(need to find 2 lip and 4 barrel)
Plan to build that parts to become 18x8in front and 18x9.5in rear. The spec will be:
- front: lip 1.5in + barrel 6.5in (offset 32?)
- rear: lip 2in + barrel 7.5in (offset 38?)
About the offset please cmiiw..
Is this ok for both e36 and e34 ? (if you have other opinion for the lip and barrel combination pls let me know). And what the tire size combination for e36 and e34?
Thank you.Comment
Just a rear fender roll. Can't go too low with the front but it fits with a small gap.I hate to ask another question that I'm sure has been answered a million times already...I started going cross eyed around page 105 of this thread and the search didn't help all that much.
Looking at 15x8 ET25 Enkei 92s. I know 205/50s fit with a 3mm front spacer and the rears are no problem. I really want to run 225/50s all around. I am blessed with big arches on my 87 so I know that helps a little. What exactly would I need to do to pull this off?
Big thumbs up, thanks!Comment
25mm adapters. Could use 205/45, 205/50, 215/45, or 225/45 safely.I was looking at a set of wheels that are 16x7+45 and 5x114.3. I've got a late model 325i on h&r sports and bilstein sports. I was thinking to run either 20 or 25mm adapters with either 205 or 215 and a 40 or 45 tire?. Would this setup work, rub, and/or require the any fender rolling? I was looking at the high offset so I can get kind of close...-ish to the stock offset when paired with adapters. But you'd know more than I would if that's a good idea or not.
Thanks a lot!Comment
I bought some 16x7 ET38 wheels labeled as Enkei RF-2. What spacers (if any) will I need to run on a stock suspension '87 vert? Was looking at 205/45/16's for the tires.Comment
You will need rear spacers. Not sure on how large as Z3M + E30 muddies my brain calculations a bit. I'd guess 15-20mm but again, that's a guess. Best to test fit then buy the spacers. 235/40s will fit all around once you get the rear spacers right.Comment
ASK ALL WHEEL/TIRE FITMENT QUESTIONS HERE - The Official Wheel/Tire Fitment T...
I've looked everywhere!
How do I achieve this.
I know they are corrodo steelies I just want to know tire size and wheel width/offset
I found the build thread
It has everything but offset
Wheels are 15x8/9
Tires are 205/50 and 225/50
The rear may be a little overkill could I run this with et0 front and rear?
I would prefer a 225/45 out back
Can I do that without flares?
I have a 87 325e, 1.5" drop using bilstein sports and eibach springs.
Will these wheels fit? Or is the offset completely wrong?
Haven't you ever seen Russian Nesting Dolls? They work like that.
1987 325e / 2008 135iComment
