	This is a sticky topic.
 Completely wrong.I have a 87 325e, 1.5" drop using bilstein sports and eibach springs.
 Will these wheels fit? Or is the offset completely wrong?
 http://www.ebay.com/itm/4-16-INCH-WH...p2054897.l4276Comment
 Dear wheel fitment gods, here is what I have:
 Fr - 17x7.5 et38
 Rr - 17x8 et20
 Im doing a turbo build at the moment and want as much rubber as I can get on the ground. What am I looking at as far as tire size and spacers needed? Im lowered on Billies and BavAuto springs (probably Eibach). I'm all stock other than M3 offset CAB up front. I am fine with rolling the/mild pull, just nothing crazy. I'm also not interested in dumped/hella flush.
 THANKS IN ADVANCE!Comment
 I am very lazy and do not what to go through 400 pages to find my specs. Though these are pretty common and I'm sure they are only a couple pages back. Then again I am lazy.
 16x9 et20 stock suspension. What tires should I run? I don't want to stretch. Normal size will be fine for me. Thanks again for your services.Comment
 Does anyone know the lowest offset I can go on TRM C1 15x7 with 205/50 tires, I have a moderate drop and the current ET is 25
 EDIT: with no fender modification/rolling
 image (10) by serdar.gurhan, on Flickr
 PM me for custom shift knobs and stickers!
 Originally posted by marshallnoiseYou ain't done working on a car unless you are bleeding.Comment
 Regardless of what the claims are there's no possible way 15x9 +4 225/50 fits.Last question I promise.
 If this guy can fit 15x9 et 4 with 225/50 all around, I should be able to fit 15x9 et10 with 225/45 all around right?
 Obviously I will need to do some rolling/pulling
 Your setup is on the ragged edge of what works, but it's possible if you're not too low.Comment
 Your rear offset is going to limit you to 215/40 tires unfortunately. If you want wider you'll need to find +25 to +30 rear wheels (for the 235/245 fitment option).Dear wheel fitment gods, here is what I have:
 Fr - 17x7.5 et38
 Rr - 17x8 et20
 THANKS IN ADVANCE!
 That said, with a 15mm front spacer and 215/40s all around that is still a solid setup if you buy the right tires.Comment
 Anything wider than 8" requires stretching to fit an E30. Are you trying to fit those wheels all around? It's an aggressive look that requires narrow tires.I am very lazy and do not what to go through 400 pages to find my specs. Though these are pretty common and I'm sure they are only a couple pages back. Then again I am lazy.
 Funny enough the wheel company contacted me. They ended up having the original size I wanted. So now the question is what tires for 16x8 et25 all around?Comment
