	This is a sticky topic.
 Looking for 16s for my car slightly lowered on H&R sport suspension. What width/ offset is recommended? Would like to avoid steering problems/ rubbing issues.
 What tire size?
 Was looking at these: http://www.ebay.com/itm/MRR-FF3-16X8...e818a3&vxp=mtrComment
 In general most wheels up to 8" wide work well in a +15 to +25 offset.Looking for 16s for my car slightly lowered on H&R sport suspension. What width/ offset is recommended? Would like to avoid steering problems/ rubbing issues.
 What tire size?
 For those 16x8s, you will need 3mm front spacers and either 205/45 or 205/50 tires. No rubbing or rolling.Comment
 Ok, slight update. Going to pick up some used 16x8s et15 with 225/45r16 tires on them.
 How should I expect those to fit?
 P.S. You're awesome.Comment
 Awesome. Only tire I could find is the Toyo T1Rin 225/40 and I could only find one in the country. All the 215/45 that I can find are super wide shoulder tires like the 615k or the ASX.
 Guess I need to order tires from across the pond. Sigh.Comment
 17x9 et35 will this clear the front struts? if not what size spacer should i get?
 17x10 et20 for the rear will be okay?Comment
 20mm front spacers should leave you paper-thin clearance and work with a stretched tire. Rears will bolt up as is, with the same tight clearance as the fronts (with the trailing arm this time). I'd use 205/40 225/35 tires.Comment
 I just bought a set of xxr 531 wheels for my 90 325i thay are 16x8 et20 and I run pritty low on coil overs (2in sectioned tubes) and willing to roll fenders what are my tire options .. I would love to do 225/50/16 but not sure if thats to wide.. ps will soon be auto cross car
 Sent from my SCH-I535 using TapatalkComment
 Im am wondering if i can fit these wheels/tires with out fender rub. I havent been able to find a clear answer for this combo
 BC coilovers 88 iS not tucking, very little wheel well gap.
 205 55 15 tires on:
 15x8 et25
 and/or
 15x8 et20
 or stick with
 15x7 et251987 325iC/5 Alpine White/Cardinal
 1988 325iS Lachssilber/Natur
 sigpicComment
 225/45/16 fits with a fender roll.I just bought a set of xxr 531 wheels for my 90 325i thay are 16x8 et20 and I run pritty low on coil overs (2in sectioned tubes) and willing to roll fenders what are my tire options .. I would love to do 225/50/16 but not sure if thats to wide.. ps will soon be auto cross car
 First ones need 3-5mm front spacers. Otherwise that tire size works on all.Comment
