This is a sticky topic.
  • e30james325
    • 202
    #7186
    when using a 5mm spacer, do i still need to replace my bolts?
    what is the best brand of spacer available and are spacers safe to use?
    is it true that you need to torque your wheels every week when using spacers?
    sorry for the ignorance...
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #7187
      Depends on the wheel hub's thickness. Rule if thumb is 6 full turns on the bolt. Don't worry about brands. No, torquing is the same process.
      • JMAL
        • May 2013
        • 312
        #7188
        ok oem 1) BBS style 8s 16x7.5 et 15 2)bbs style 5s 16x8 et 23 3)bbs style 29 16x7 et 20
        drill and fill or adapters on bc coils not dumped. Looking for flush (no poke or very little poke) and mild fender rolling at most.
        for each, what is the best fit? also what spacer/adapter would be needed for meet my needs. Im not sure if these will hit the caliper or poke after clearing it.
        thanks
        1987 325iC/5 Alpine White/Cardinal
        1988 325iS Lachssilber/Natur
        • Mystikal
          • 9602
          #7189
          thanks
          None of them are ideal for adapters. All are suitable for redrilling.
          • JMAL
            • May 2013
            • 312
            #7190
            ok thanks, on the 8 inch wide, whats the lowest total offset using spacers that i can get to be flush?
            • newman8r
              • Feb 2014
              • 683
              #7191
              I have a fitment question. I have some bottlecaps that I am getting rid of soon. I want to lower my car with vogtland springs which will drop it 1.8'' all around. I want a wider tire than I have now (6'') What is the most I can go without rolling the fenders? offset and tire and rim suggestions welcome...
              Should I lower first and see what I can fit or buy the rims first?
              • totheredline
                • Jun 2013
                • 762
                #7192
                Anybody tried Falken Azenis RT-615Ks? Im looking for a really grippy summer tire for my US weaves. The car will be autocrossed. Any other tire suggestions?
                the only size 615k for 14 inch wheels is 195/60r14.
                I believe stock tire size is 195/65R14?
                = Heidi 1988 325 -> 335i. 7200rpm built M30
                • Mystikal
                  • 9602
                  #7193
                  +10 is good.
                  • Mystikal
                    • 9602
                    #7194
                    Read anything in this thread, really.
                    • Mystikal
                      • 9602
                      #7195
                      They're good, not great. Not sure there are any other choices still produced in 14". Look into the Hankook R-S3 or Dunlop ZII to see if they're available as they're both a bit better than the Falken.
                      • mmeyer08
                        • Sep 2007
                        • 163
                        #7196
                        What size wheel studs should I get that won't be to long, or to short to run my center caps, and the 15mm spacers.
                        16x7 et35 konig remembers
                        15mm spacers
                        fun
                        • F34R
                          sLaughter
                          • 12385
                          #7197
                          15mm spacers
                          You will need 64mm studs:
                          Instagram: @BWeissLeather
                          Current cars:
                          ~ '87 325 M30B35 swap
                          ~ '87 535
                          ~ 01 540 Msport 6spd
                          ~ '06 X5 4.8is
                          • totheredline
                            • Jun 2013
                            • 762
                            #7198
                            i found the dunlops in 185/60r14
                            So dunlops in 185/60/14
                            OR falkens in 195/60/14. hmmm
                            Would 195 offer a ton more grip over 185?
                            • Stevoyayaya3
                              • Aug 2013
                              • 315
                              #7199
                              Has anybody had any luck with using 6-7" lips as barrels? I guess the valve stem would have to be on the inside as well.
                              • Mystikal
                                • 9602
                                #7200
                                15mm spacers
                                Sorry, long forgot stud measurements. I know 75mm is gigantic and won't work, but otherwise unsure.
