	This is a sticky topic.
 Thanks
 Thanks a lot, I ended up ordering the 64mm studs. They were to big, but Ryan Castro from motersports hardwear (a fellow e30 enthusiast) contacted me, after my wrong order, to make it right. My order got fixed, I'm glad they know there business over at motersports hardwear!
 Big thanks to you aswell Mystikal!
 Cheers mates!sigpic
 funComment
 Im interested in some OZ turbos...
 There specs are:
 15x7 et15
 15x7.5 et9
 For this setup would I be better off with a 195/60 tire all the way around or 225/50? Or is there a better option? I do autocross my car and can roll my fenders. My suspension is ground control coilovers and only my rear tires are barely tucked. It is important that the wheels line up nicely with the fenders, will this require a rear spacer?
 ThanksComment
 I have a set of 16x8 et23 weaves off of an E38. I plan on using the adapters 8380 sells. Question is, what size adapters would you run? Looking for aggressive, but not a big stretch or anything like that, probably a 205 series tire. Also, I'm on GC coils with shortened housings, so the car is low.
 Thanks for your help!- 2009 BMW 535xit
 - 1987 325isComment
 Hey guys I'm going to be buying some wheels soon and I'm trying to decide between 16x9 15 offset and 3 inch lip or 17x10 15 offset with 4 inch lip.. My car is lowered on catuned coilovers and is decently low. I was wondering if 17x10 will be tough to fit and I should just go with 16x9 since this car is my daily.. I know I'll probably need some spacers here's a picture if my car currentlyComment
 205/50 all around is your limit, even with a rear fender roll.Im interested in some OZ turbos...
 There specs are:
 15x7 et15
 15x7.5 et9
 ThanksComment
 18mm, 205/45. Rear fender roll.I have a set of 16x8 et23 weaves off of an E38. I plan on using the adapters 8380 sells. Question is, what size adapters would you run? Looking for aggressive, but not a big stretch or anything like that, probably a 205 series tire. Also, I'm on GC coils with shortened housings, so the car is low.
 Thanks for your help!Comment
 They will be sunken way into the fenders as they sit so I wouldn't worry about fender mods. 185/65 would the correct size, but if you're trying to make it look nice I'd suggest 195/50 or 185/55.Comment
 I wanted to check that…
 AVID.1 16x8 +25 wheels… I was thinking about sticking on 5mm spacers as well for a more herra frush look (not so much)
 Running 205/50/16. Is this a more square tire? when i put this on the rim, will it stretch? or bulge? I don't like the bulge look i'm getting on my 14" bottle caps. Running 195/60 or something right now. It's ugly.Comment
