Any chance of fitting 17x8.5 ET12, 235/40/17 Falken RT615k? Fenders are pulled front and rear, GC 600/800 coils with shortened housings, just wondering if I will clear the inside of the quarter panel in the rear
	This is a sticky topic.
 Ok, sorry if this has been answered already, but will 17x8 et20 Style 32's fit/clear an E30 with 99 E36 M3 full front supsension/brakes and full M roadster/coupe rear suspension brakes? Looking to buy a set local to me and just want to confirm if it's feasible.
 I plan on running GC's setup: http://www.ground-control-store.com/.../II=812/CA=242
 Thanks!Comment
 318iS on joms. I have 16x8 / 16x9 wheels. What tires i buy for them? Im thinking
 i want mild stretch so im thinking 195/45 - 205/45 or 195/45 - 215/40 setup. I looking for similar sidewall and similar look
 Sorry for my bad english!Comment
 The fronts would be flush/poking and the rears will be sunken in slightly. You can balance this out with spacers, but 205/40 tires are your limit.Ok, sorry if this has been answered already, but will 17x8 et20 Style 32's fit/clear an E30 with 99 E36 M3 full front supsension/brakes and full M roadster/coupe rear suspension brakes? Looking to buy a set local to me and just want to confirm if it's feasible.
 Thanks!Comment
 205/45 225/40 if the offsets are perfect. 195/45 215/40 otherwise.Comment
 205 tires are the limit all around or just at the front? I'll be running about -2° to -3° camber on the front. No more than that though.Comment
 I'm assuming this is without a roll and slight pull? Will be doing both. Regardless, I need more meat for S54 power. I would like to fit at least a 235 in the rear.
 Can 17x9's with a proper offset( ~+35) work on the front?Comment
 But would 215/40/16 be good both, rear and front? Or better to use 45 height?
 I try to get the same wide tyres, otherwise the front look stretch and rear not.
 ThanksComment
