i wanna just know the most backspacing for front and back with a 17inch rim?? i got a late model, on coilovers(joms) but switching to better ones.
	This is a sticky topic.
 Alright, lets try this again... the right way.
 1987 325es
 Final tire choice:
 Toyo R888 in 255/50r16
 Wheel can be a 16x8 or 16x9.
 Would like to avoid flares, but will be doing some SERIOUS fender pulling/modding/shaping.
 What's the best offset?Last edited by AWDBOB; 03-16-2014, 12:54 PM.Comment
 Mystikal - I know this is e30 specific, but do you have any M3 experience?
 I'm wondering what the lowest offset I can safely run 225/45/16 on 16x7.5 wheels. Would et07 be rub city on the front?
 Sent from my iPhone using TapatalkComment
 Answered my own question. I totally forgot I had a factory E28 M5 spare tire in my E28's trunk, so a bit of test fitting.
 Specs:
 16x7.5
 et 20
 225/50/16
 10mm spacer
 The tires are obviously too tall, but the pacing doesn't look to be bad.
 DSC_8477 by ericandshovin, on Flickr
 DSC_8478 by ericandshovin, on FlickrComment
 Looking into a new setup for autoX this summer. Car is an 87 325is, GC coils that are currently way too low but will be fixing that.
 I know 15x8 TRM C1's with 225/45 Hankook RS3's are a tried and true combo, they require just a bit of fender rolling, correct?
 Also looking into 15x9's, wheel in particular is 15x9 et15, again with 225/45 RS3. What sort of spacers/fender work would that require? Thanks. Comment
 Will 17x9 et20 work on a 87 325is with blitztein HD and vogtland springs? Will it clear brakes? Fender roll? Tire suggestions? I'd say its 1.5-3" below stock height gestimateComment
 215/40 is the limit all around with either setup. Maybe 235/40 rear only if it's an early car.i have 2 sets of wheels.one is a set of 17x8/9 style 32s with an offset of 26/20 and then a set of 17x8 e39 style 5s with an offset of 20. i will have e30 m3 rear 5 lug and then lativian spindle sleeves which widen the front by 12mm on each side. my question is can i run 235/40/17 all around on both sets? i am on ground controls and all the fenders will be roller. thanks!Comment
 That's over an inch too tall to ever work on stock fenders.Comment
 First setup likely wouldn't require a roll on your car, good fit. The second setup would definitely require rolling, but can work. 3-5mm front spacers may be needed depending on your front spring setup.Looking into a new setup for autoX this summer. Car is an 87 325is, GC coils that are currently way too low but will be fixing that.
 Also looking into 15x9's, wheel in particular is 15x9 et15, again with 225/45 RS3. What sort of spacers/fender work would that require? Thanks.Comment
 Hello again,
 Mystikal here is the wheel dimensions
 16X7.5" et13 BBS RZ
 offset +13
 I'd like to have them redrilled; what spacer will be needed if any and recommended tire size?My old Style 5 Thread / My Swap
 1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
 IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
 1998 528I (Sold) // 2003 540I ///M SportComment
 Hey,
 I'm looking to a set of RM's. Just wondering which offset will get me flush with the fenders - 3" lips et1 or 2.5" lips et14. Or is staggered the preferred method?
 EDIT: Nevermind, sorry I should have searched THIS thread before asking - looked through google and other threads. I now have my answers.
 Thanks!Last edited by JRYE30; 03-17-2014, 01:12 PM.
 1987 325 | @e30_hunter |Comment
