	This is a sticky topic.
 Year, Model, Suspension, All Relevant Wheel Data (Diameter, Width, Offset, Bolt Pattern, etc)
 1989 325i, Ground Control Stage 2+? coils, 500/600. Looking to run a 17x8 Apex wheel.
 What's the widest tire I can run, and what offset would I want the wheels to be to achieve that? Trying not to stick out the sides of the car, planned on rolling the fenders.. Hopefully this isnt too vague of a question
 Thanks!
 SComment
 I'm getting real confused. I'm looking at 15x7s on 205/55 tyres, but what offsets can I have? Some seem to be running as little as +15, but then I've seen up to +38. I want to keep the rolling circumference as close to stock as possible to avoid issues with fitment, just unsure on offsets.
 Also, there's a good chance this has been answered, but there's 500 pages. Thanks in advance.Comment
 I'm on coilovers, currently on 225/40/17 all around but tires are not made anymore thinking of going 245/35/17 in rear. Wheels are 17x7.5 et28
 Rear wheel with no spacer and my fenders are rolled and 750lb rear springs. Think I can do 245/35 in rear if I raise it a little?sigpicComment
 They were only made in the ideal offset (which I gave to them, heh) of +25. 235/40 is what they were designed for.Year, Model, Suspension, All Relevant Wheel Data (Diameter, Width, Offset, Bolt Pattern, etc)
 Thanks!
 SComment
 Yes, down to about +15 should work. No higher than +27. The lower within this range, the better they will look.I'm getting real confused. I'm looking at 15x7s on 205/55 tyres, but what offsets can I have? Some seem to be running as little as +15, but then I've seen up to +38. I want to keep the rolling circumference as close to stock as possible to avoid issues with fitment, just unsure on offsets.
 15mm front 20mm rear would look nice. Can also do either of those sizes all around and it will work fine.Comment
 Too wide and short of a tire for the wheel. 235/40 would just fit and work well.I'm on coilovers, currently on 225/40/17 all around but tires are not made anymore thinking of going 245/35/17 in rear. Wheels are 17x7.5 et28
 Rear wheel with no spacer and my fenders are rolled and 750lb rear springs. Think I can do 245/35 in rear if I raise it a little?Comment
