	This is a sticky topic.
 That's exactly what I would have suggested. Good work.Hey there Mystikal,1986 BMW 325ES. I have a set of BBS LM's (real deal) 17 X 7.5 with a et 40mm off set... running a 205/45-17 Dunlop Direzza tire.. know I'm going to need spacers to make them clear the front and look right on the car (front and rear )due to the offset...and longer lug bolts also... car has a E30 Bilstein Sport Shocks - E30 (set of 4) T#3714 & H&R OE Sport Spring Set - E30 - 318is 325e 325i 325is M3 T#4342(the springs were rated at lower the car a 1"... whats your thoughts... Thank you...
 Well wanted to get the new rollers on my ES for the e30 picnic, went with H&R DR spacers 57.1 bore 15MM front spacers & 20MM rear spacers..my guess work came out ok... looks darn good !.. HMM do I keep my 15 BBS RS wheels as back ups... on the fence on selling those..Comment
 Yes, rear fender roll necessary. Still will be very tight.Comment
 No issues.Hi guys, looking at some 17x7.5 +15 offset (can choose a different offset if need be) running 205/40/17's, just stock suspension at the moment and guards aren't rolled. I want to avoid guard rolling and spacers if possible. Will I have any rubbing/clearance issues?
 Thanks for your help!Comment
 Need to know the offset and width. Also, that tire size will not fit.I'm the happy owner of a 1989 325i 2dr. Still running stock bottlecaps, but now I'm looking at getting new tires and going to 16" wheels.
 I have Bilsteins on the front and rear.
 I'm looking at getting Ronal R54 rims (16") and 225/50R16 tires. I'll probably go with Continental ExtremeContact DWS 06 tires, need good wet and dry performance here in the PNW.
 Will this setup work/fit? Any spacers needed?
 Thanks in advance !Comment
 Not certain to be honest. It would be best to start with a higher offset wheel, such as a 15x8 +25 all around. This way you can run a 5mm front spacer to clear the struts and no rear spacer for maximum clearance. I'd guess only a basic front and rear roll would be necessary with this setup.Mystikal-
 Earlier this year in post #9191 you mentioned that the 245/40/15"
 "Will likely be THE hot ticket E30 size for those competing at higher levels. I can see people shoehorning them onto 15x8 +20 wheels (since there's so many of them, and a 245/40 fits well on an 8" rim) with pulled fender arches."
 I'm thinking of trying this as a autocross only combo for my car (1990 325i, IE3 springs, Billies, urethane bushings, front GC camber plates, Z3 rack) and was wondering how much the front and rear arches would need to be pulled?
 Thanks for the longtime contributions to the community through this thread!Comment
 I'd go with 235/40. They will fit.What will be the best Tyre size to fit on 17x7.5 ET28 to fill up the gap with the fenders on my 4D 320i 1985? I have D2 Racing full coilovers not yet installed, I was thinking to go with 225/40/17 or 215/45/17 I think the 235/40 is going to be wider than the wheels edge and might cause too much rubbing with the fenders but anyway I'm planning to roll my fenders to give more space for the Tyre to go inside freely.Comment
 Not even close. Same wheels in a +15 front and rear have a chance.Just bought my first e30 its a 1991 325i and it's bone stock for the moment. Looking to turn this into a major project but wanted to know if I could run 15x8 4x100 0offset fronts and 15x10 4x100 0offser in the rear on stock suspension.
 Will I need to roll my fenders? Do they fit ? Any not to expensive coilovers someone could recommend?Comment
 Go with the 16s. No spacers and 205/45 tires all around. Can also do a 195/45 up front for a matching stretch look.Hi Just got myself a 1985 E30 323i Baur TC
 Looking at getting some JOM coilovers.
 Wondering how a set of 16x8 et20 up front and 16x9 et15 would fit. Would I need spacers? Also what tyres would work?
 Other option is 17x9 all round et20 would that work all?
 Thanks in Advance.
 BradComment
