This is a sticky topic.
Hey... Im thinking about throwing stars on my 4 lug e30. Have access to 18mm 42draft adapters. So my final et would be 2 square, i have rolled and slight pull rear fenders and rolled fronts, sitting on bilstein sports and ies3 springs with 15mm drophats in front. What tires should i use to make it work? Would i have rub? Thanks...
205/40s should work with your existing fender work. It might still rub in the back with passengers.Comment
Yes they are 8 square.. I really dont want rubber band tires!! Would i get away with 215/40 at least or no way?
One of the best threads you will ever read
http://www.r3vlimited.com/board/showthread.php?t=221813
Nice trailer of my e30
http://www.youtube.com/watch?v=TTjtG...e_gdata_player
If i sold you something please leave feedback here
http://www.r3vlimited.com/board/showthread.php?t=217142Comment
read through a lot of this, but hard to search for what i'm looking for.
car is a 12/92 build date cabrio and have staggered 16" esm002r's on stock suspension. Looking for a good tire size/brand, spacer recommendations, and fender rolling needs that will show a little bit of stretch, no poke and minimal to minor tire-to-fender gap.
I realize i'll have a fender-to-tire gap until I get some suspension. a coilover package is next on the list (likely something like the BCs/CAtuned stuff).Comment
hi;
I am about to acquire BBS RS 16x7J ET25 wheels. what would be the widest tires i can fit on e30 without them scrubbing the wheel wells? i run everything standard and do not want to use any spacers
215 or 225/45/16 be an issue? what do you recommend jay?
thank you.
teoComment
Just got my hands on a set of genuine alpine's 17 x 8 and 17 x9 et 46 for both f and r. looking to put these on a touring with 20mm adapters, is this possible with a final offset of 26 all around? and if so what tires front and rear? I do intend to put stuff in it from time to time two regular adults and bicycle gear. car is on ground control coilovers. Thanks in advance for all you do for the community!!!FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
Im looking for some help with fitment on a set of rota grids. Currently I am running a set or borbet alloy wheels that are 16x7 and I believe 35 offset. I have the borbets wrapped with 195/65/R15. I am looking at a set of 17x7.5 grids with an offset of 45.
SO here are my questions.
-Obviously, will they fit with ease? Im expecting to have to roll the fenders. Im trying to avoid using any spacers.
-On my current borbet wheels, I measured the outside of the rim and came up with 16 inches, but why would the wheel width on the tire say 15?
-Would 215/50/17 tires fit around 17x7.5's? Should the width/profile be higher/lower?
I should probably add that the car is lowered on raceland coilovers about 2&1/2 to 3 inches.
Any help would be very greatly appreciated.Last edited by mrdunne30; 12-08-2014, 09:27 AM.Comment
Currently got some 15" BBS RS and need some new outer lips and tires.
After a look like this (on my non ix e30):
Will 205/55/15 fit on 15x8.5 ET7 and 15x9 ET3? Or would 8 and 8.5 be a better fit?
Unfortunately can't get 225/45 where I'm from and thinking 225/50 might be too fat? 205/50 seem too small to me.
Appreciate the help!Comment
I am going out on a limb here, I asked for a photoshop of these wheels for reference, but has anyone ever tried to put a set of these on an e30?
I need tires, and have these "available" to me. THey are not in my possession, so that is why I ask the question. 4x100 dodge Shelby wheels from the 80s. What say you R3V?Last edited by rcsoundn1; 12-09-2014, 07:53 AM.Comment
I'm looking at getting 15x8 TR Motorsport C1s (et20 I believe) and putting some 225/55/r15 tires on them. Would those fit without rubbing? 1990 4dr on billy sports and h&r race springs all around. Fenders are slightly rolled as well. ThankssigpicComment
