This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #7936
    Originally posted by Rickaytan
    What would I need to fit 4x100 16x9 et23 wheels with a centerbore of 73.1? I have ground controls and I am slightly lowered about 2 inchs.
    12-15mm spacers all around, 73-57.1mm hubcentric rings, and extended bolts. 205/45 or 215/40 tires.
    • Mystikal
      • 9602
      #7937
      Originally posted by gordie
      Kind Sir, what offsets for 17x8 and 245/40/17 with rolled fenders and maybe pulled a bit, lowered 50-60mm
      Edit: btw the big attraction for this size is hand-me-down r spec tires from a racer dad's workshop supports.
      Are they just R-comps, or something more like Hoosiers or Grand-Am takeoffs? The former has a slight chance of working, the latter are much too wide.
      +22 is about ideal
      • Mystikal
        • 9602
        #7938
        Originally posted by RegularEverydayETA
        I'm sure it's been covered already but I can't seem to find it. Need to know what's size tires and spacers to use with 16x8.5 et32 Salad shooters. I don't want to roll fenders
        Whatever.......
        15-20mm spacers and 205/45 tires.
        • itskingsteelo
          • Jul 2013
          • 1340
          #7939
          How would 17x8 et35 fit? I have 10mm spacers up fromt and 12mm in the back
          Originally posted by dvck
          • Mystikal
            • 9602
            #7940
            Perfect with the spacers. You can fit 215/40 stock, or 235/40 (both all around) with a rear fender roll.
            • KnockOffBrand
              • Feb 2014
              • 58
              #7941
              Hi, so I have some 15x7 rims with somewhere between +20 to +30 offset. I'm looking for new tires and want to put 205s on instead of the 195s. What would be a good sidewall size for a 205 tires on 15s? I've been looking at 50-65 and I would like to know which ones of those sidewall sizes would work. I'm currently on Billy sports and H&R race springs with rolled fenders. Thanks.
              • dtm@heart
                • Sep 2009
                • 82
                #7942
                1991 318is on billies and H&R sport, no fender mods on Hartge 17x7.5 +20 and 205/50/16. I'm trying to decide between 16x8 +20 square or 16x8 +20 16x9 +15 stagger.
                I know it's not a particularly hard setup to figure out but I want a somewhat classic fitment. With the staggered setup, what size tire would you run, and would I potentially need to roll if I kept the 205/50's? TIA.
                • Mystikal
                  • 9602
                  #7943
                  205/55 is the stock size, but 205/50 works fine too.
                  • Mystikal
                    • 9602
                    #7944
                    With the 16x9 rears you will need stretched tires (205/45 or 215/40) and a low ride height. I say stick with the 16x8s. Shouldn't need a roll with 205/50s.
                    • catech11
                      • Feb 2014
                      • 83
                      #7945
                      17x7.5 et 45 4x100 with 205/40 tires? Car is 1989 325i on H&R sport Billie combo with rolled fenders all around
                      • icebox
                        • Nov 2014
                        • 8
                        #7946
                        Can the touring fit a 17x9 et20 + 17x10 et25? What's the best tires for this setup? Only suspension mod is that it sits on Eibach pro kit
                        • Mystikal
                          • 9602
                          #7947
                          Way too high of an offset. They'd look and work best with 25-30mm spacers.
                          • Mystikal
                            • 9602
                            #7948
                            Needs spacers front and ear due to interference. 10mm front 5mm rear. Would then need rolled fenders and 205/40 and 215/40 tires. Also may have to switch to coilover to add ANY weight in the rear or cargo area due to the softness of the Pro-Kit and the extremely aggressive wheel/tire setup.
                            • redreda1313
                              • Nov 2014
                              • 33
                              #7949
                              I wanna wanna run filled and drilled 16x8 style 5s et 23. What size spacers and tires should i get for flush fitment? Car is lowered on bav auto springs and bilstien sports 1 1/4" lower then stock height. if i used 8mm spacers all around, can I run 215/45 or 225/45?
                              • schtozo
                                • 1455
                                #7950
                                Hey... Im thinking about throwing stars on my 4 lug e30. Have access to 18mm 42draft adapters. So my final et would be 2 square, i have rolled and slight pull rear fenders and rolled fronts, sitting on bilstein sports and ies3 springs with 15mm drophats in front. What tires should i use to make it work? Would i have rub? Thanks...
                                One of the best threads you will ever read
                                http://www.r3vlimited.com/board/showthread.php?t=221813
                                Nice trailer of my e30
                                http://www.youtube.com/watch?v=TTjtG...e_gdata_player
                                If i sold you something please leave feedback here
                                http://www.r3vlimited.com/board/showthread.php?t=217142
