	This is a sticky topic.
 I know this is pushing it a bit. helping a friend with wheel choices etc
 7.5j et20 16"
 195 45 16
 15mm 4x100 to 5x120 adapters. can it work?Comment
 easy. Your final fitment will be 7.5j + 5mm. An equivalent would be 8J+11mm. You can run wider tires if you want.
 Thinnest adapters I have seen are 18mm though2014 Alpine White 335i MSport
 (Daily Driver)
 Full Mperformance Aero
 KW V2 Coilovers
 VRSF Catless DownpipesComment
 You will be limited to 205/40 fronts. 215/40 rears fit with a flat roll and coilovers. Everything else is far too big.I have a machined 5 lug conversion, pushes front out 12mm each side. rear is e30 m3 5 lug width, same as stock. I have a set of style 42 17x8 et 20 all around, im thinking about strapping them with 225/45/17 or should I go 40 aspect ratio? Thanks in advance for the help!
 P.S. currently on eibach springs and bilstein sports, soon to be on full ground control coil overs, I have no problem rolling fenders if need be, fronts are already rolled a bit from P.O.Comment
 Neither proposed idea will work.Background:
 I'm currently running 16x8 et8 front/16x9 et15 rear with 225/45/16 Falken FK452's all around. I'm happy, but I wish I went 16x9 square.
 Tires are almost shot, and the only thing I can find without shipping internationally are two Toyo Proxes T1R 225/45/16 (and they're on clearance for $75/pc). I can ship two 245/45/16 of these for another $400, and I feel it is worth it.
 My questions:
 1: With 16x9 et15, how hard is it going to be to fit 245/45 in the rear? It is already rolled and pulled somewhat, but it looks pretty close as is.
 2: I plan to swap the fronts out for 16x9 et15 as well, which will push my wheel out 6mm more. I've test fitted my current rears to the front and with a 225 it looks like it will work, but would you call me crazy if I try to fit 245's up front after I run out of 225's?Comment
 245/40 should work but you might need to raise it a bit.Late Model e30 with rolled fenders on ground control coils, lowered but not dumped.
 - car is a turbo car (s52 turbo making 500+whp) so looking to fit largest rear tire I can on the apex acr8 17x8+25 wheels.
 Can I fit a 245/40 out back on that wheel? or should I stick to a 235/40 square setup?
 - street tires also no Hoosiers. Most likely NT01/Toyo R1R/R888
 Thanks!Comment
 15x8 et25 enkei classics
 From what Ive read this setup isnt a perfect fitment, but the price is great for a new wheel, and I like the look.
 I am at stock ride now but may get lower by up to 2".
 What are the recommended tires / spacers for this setup?
 Forgot to mention This is for a '91 318is.
 Thanks !Comment
 Anyone know what's the widest tire I could mount on a 17x7 wheel 40 offset I could run 20mm spacersBuy e30 cup holders
 http://www.r3vlimited.com/board/show...41#post4159541
 Buy BMW Motosports handles
 http://www.r3vlimited.com/board/showthread.php?t=302846
 Buy BMW MOTORSPORT valve covers http://www.r3vlimited.com/board/showthread.php?t=330146
 sigpicComment
 You will need 5mm front spacers. 205/50, 205/55, 225/45, and 225/50 all work.From what Ive read this setup isnt a perfect fitment, but the price is great for a new wheel, and I like the look.
 Thanks !Comment
